dont have a bdm for this have an ori read , think my mpps
only bdm one l have is
Hardware Version: 5WP45600AC
Software Version: 6576286349
Upgrade Software: 03G906018CD 9970
but thats not good for you
Hello! Does anyone have full BDM read for this ECU? You have attached my partial read with MPPS V16. Car is a VW Passat 2.0 TDI BKP 140 HP 2007. Thanks in advance!
03G906018FG
SN100L3000000
03G906018FG-Passat-2.0-tdi-BKP-2007-PPD-1.rar
mcday (29th October, 2017)
Thank you anyway. Maybe someone else have the right one.
Hi! Can anyone confirm that one of this is the full bdm read? In PPDMaps says that they aren't
BDM.rar
thats shows all ff in start off bin
my bdm read is 00 in start
normally obd reads fill blacks with ff
CrBooster (15th January, 2017)
Ok Thanks! Still looking for that BDM file then.. Or have anyone instructions on how to read it? I have Kess, Ktag and BDM Frame.
are you looking for bdm in case obd write fails ?
Yes. I also have MPPS V16. I used it to read and write a PPD 1.1 without problems but on PPD1.5 i read that someones have some difficulties.
havnt read to much about kess havin problems if you have a good one , normally if it reads ok it will write ok , use a good power supply should me ok . l have one here but l dont think theres an obd pinout of this ecu, if there was l would try on bench for you , siemens are better to write to ,
kess is very good on older cars and so is mpps
Another reason that I'm in doubt on using KESS V2 is because on this particular car, it says it have EDC16U ECU instead of PPD 1.X
just read id and file if thats ok it will write ok ( more than likely)
And should i select correct car but with that wrong ECU that it gives or should i select a different car but with corect ECU PPD 1.X ?
even you picked wrong one kess tells you the right one , pick your ecu and read id
Ok! Thank you very much! I will give it a try this week and i will tell you how it went.
smirnoff is right my friend !!!
smirnoff_rules (15th January, 2017)
