Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    May 2015
    Work few minutes today on this. J1 have bkgb,5v and ground but not continuity with reset pin to j1 but ok i have place to solder the reset. And have continuity between vddx1-vssx1 and vddx2-vssx2. Ground with ground and positive with positive. Try to read tomorrow with usaprog
  2. #17
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by Berubeg View Post
    use my pinout, it's correct for your job mate.
  3. The Following User Says Thank You to jomberykaso For This Useful Post:
    Berubeg (23rd January, 2017)
  4. #18
    May 2015
    Yes friend. But make this for learn and like check my knowledge. Thank's mate
    Quote Originally Posted by jomberykaso View Post
  5. #19
    May 2015
    it's a test for transfert file. i read with usaprog. i think the mileage is on line 0020 (13D908) and 0030 (13D908) someone could help me to valid this. It's appreciated friends
    And if like 3500km i'm good if replace by 305705
  6. #20
    clusters's Avatar
    Mar 2015
    Canada
    Your calculations look good, but I suspect that will give you an error because of the checksum at the end of lines 0020 and 0030.
    Looks like a simple addition checksum +1
    Try 30 57 05 00 xx xx xx xx xx xx xx xx xx xx ca a9
  7. The Following 2 Users Say Thank You to clusters For This Useful Post:
    Berubeg (25th January, 2017), Johnner (26th January, 2017)
  8. #21
    May 2015
    Hello cluster. If is possible for you to give me little bit more info about checksum here or by pm. Or You have a place for read more about this. Realy appreciated.
  9. #22
    clusters's Avatar
    Mar 2015
    Canada
    Did you try it? Not sure if this is correct for this one, but it is used in other algorithms.
    Add words, xor with ffff add 1
    Original:
    13d9
    0800
    1bd9
    Xor = e426 + 1 = e427
    New
    3057
    0500
    3557Xor = caa8 + 1 = caa9
  10. The Following 3 Users Say Thank You to clusters For This Useful Post:
    Berubeg (26th January, 2017), SergeyIg (15th September, 2018), vasa (26th January, 2017)
  11. #23
    May 2015
    cluster i'm drive few km and this is the result for compare the checksum. it's not clear for me i'm calculate this evening!
    tundra5802.2km.bin.zip
  12. #24
    May 2015
    Why in line 0040-0050-0060-0070 some value change between 2 files? in two file trip km a,trip km b and trip hours are reset to 0
  13. #25
    May 2015
    Cluster all work good! Thank's for your support
  14. The Following User Says Thank You to Berubeg For This Useful Post:
    clusters (26th January, 2017)
