Results 1 to 2 of 2
    Default VW Golf V 1.9 TDI BLS 77kW, 03G906021FD need original file
    Hello everyone,
    I am having trouble with a Golf V , some strange errors regarding MAF and boost leak that appeared since the customer took out the DPF and did a DPF off on the ECU (at another garage). I want to see if the errors are from a badly changed map , so I am looking for an original 03G906021FD Bosch EDC16U34 0281013089 file (or a good DPF off on this file) . If you have such a file pls upload it here.
    PS: All I have for the 1.9 TDI BLS is a 03G906021HB which is a bit different (I think newer, 1 more temp sensor etc).
    Thank you.
    EUROPE
    here if i helped you thanks and rep please
  3. The Following 3 Users Say Thank You to kospoz For This Useful Post:
    CARPARTS (27th February, 2018), cd_contact (5th April, 2017), hark87 (20th January, 2017)
