tolk with suport team zedfull about the problem zedfull dammage the car
Hello All,
I got really big problem on this car. Customer came to me for second new key. Its smart keyless go key AES inside.
I connected the Zed-Full then tried to program the new key. Its told me Succesfull but when i tried to start the car it wasn't start.
then i tried 2 more times and car has been shut-off complately. Now car isn't starting with any way. even if i push start button there is no action like i don't pushing it.
Anyone has any solution for this car ? Please let me know by whatsapp +90 537 440 22 22 or skype
Erem GUNES
Istanbul/Turkey
Working with Immobiliser systems..
Could you try to release steering lock.
And try just add only the old key back once more.
And check if it start OK.
Then remove the key blade on the new key. And check the blade if it is empty or has 7936 inside.
Because the smart case had 7952. Two ID's at the same time, when trying to add.
I got one of those (Not on Qashquai, but smart),and it confused me. It would not add. And all stopped, working. Not start. Add back original. And working again.
Had to send it away out running again with only original key.
Needed then to find out what happened.
Found out this. (And I don't think it is supposed to be like this). Supplier made a mistake I think.
And will add it again later with a new empty blade. I never did check the original working one. If it had a 7936 inside the blade.
I suspect there is a chance to add only blade with 7936 as a separate 3key? Without remote. Maybe someone could confirm this.
i contacted to them but they only refunded 160 tokens back to me. They do not take responsbility.
This car has Hitag 3 AES its not PCF7936 or 52..
Erem GUNES
Istanbul/Turkey
hello
my friend in france have exactly same problem in same car last month , and no find solution car goes to nissan on truck, and key + programmation cost him 360?
becarrefull zedfull user on this cars .
i wish you solved it , good luck
eremgunes (19th January, 2017)
Im explaining the solution.
The ELV is going to locked position after some problems (it might be pin code calculation or wrong proccess).
then car goes to sleep,even if you press start there is no action by car.
In this case you must repair the elv then car goes wakeup. Last process is key programming.
Thats it.
I just fixed my problem like this.
Erem GUNES
Istanbul/Turkey
key4man (11th February, 2017)
hello
i got the same problem i try to repair the ELV but doesn't work, so i did ordre a new ELV and am waiting to receive it and try .
PAIN is Not Our Enemy.. It is a Call To GREATNESS!!
