Results 1 to 9 of 9
    Dec 2010
    Default KIA Optima 1.7 CRDi EGR OFF
    Hello friends,
    Could you help me with EGR OFF in this file ?
    DTC: P0404 (limp mode 3000RPM)
    EDC17C08
    Read BOOT FGTECH
    0281018188
    39120-2a302
    Thanks in advance!
    Here you go Pass PM
    Test and report
  3. The Following User Says Thank You to tomek3232 For This Useful Post:
    xdamdamx (18th January, 2017)
    Dec 2010
    tome3232 it's off by hysteresis, thanks! but DTC P0404 (EGR position ) is active, and limp mode still.
    Check EGR, if it is open, close it
    Dec 2010
    It's closed, but the position sensor is faulty.
    Babos's Avatar
    Mar 2012
    because there is electronic problem!
    Dec 2010
    It's related to hall effect sensor in the EGR, if i connect new egr just for a moment, the fault is gone and engine revs normally. On old one i have 3000RPM and P0404.
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Even with dtc off still will be in limp mode ! you have to bypass debouncing time from egr !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  10. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    pike (18th January, 2017), stanislav georgiev (18th January, 2017)
  11. #9
    pike's Avatar
    Sep 2013
    Quote Originally Posted by mihaiservice View Post
    Hi.
    What debouncing time to use in this ECU? Value is usually 0.1s.
