Results 1 to 3 of 3
    Aug 2015
    BEHIND YOU
    Default nissan murano 2009 smart key help to reprogram after a failure with skp tool
    hello i have receive nissan murano 2009 with 2 smart key,,,
    the remote work ok but if i need to start the car i have to put smart key inside the slot card....
    it could not be started when smart key is outside slod card....
    so customer asked me if i can fix the key to start the car without putting them inside card slot
    i have try to reprogram the smart keys
    i have read bcm i get 17FCA
    so i have use skp900
    i have enter pin code to realase steering lock... i have try 0383 and 2925 . this procedure was succes
    then i have enter key program procedure... i have get error.... communication failed
    and now the car could not be started with all key...
    i have try all car and type on nissan menu without succes...
    i have try to remove battery cable for some minutes without succes...
    when i put key in card slot the immo light turn off on dash... but car could not be crancked to start
    i admire any solution
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
    ray-ray's Avatar
    Note: All 2009-2014 Murano models have Push Button Ignition. But models with NO Power Liftgate & NO Prox
    Buttons on the Door Handles do not have real proximity and require the remote fob to be inserted into the slot
    on the dash to start the vehicle.
    Most 2009 models still use the “older” 2004-2008 PIN code convert
  3. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    doctore (19th January, 2017), lupu_sandu (19th January, 2017)
    Aug 2015
    BEHIND YOU
    hello problem soved with ck100
    the keyless wass missing the trunck button so it was not smart key
