eis number?
upload new flash
Lost Keys. Created key and day 1 the vehicle ran. Day 2, no crank anymore.
Read using SMOK.
Attached DAS Overview, is that normal?
Someone stated damaged flash, would this occur after a few successful start?
eis number?
upload new flash
doctore (19th January, 2017)
Will get the EIS number tomorrow hopefully.
A906 545 48 08 MC9S12 EE SEC Original.rar
A906 545 48 08
Attached is EEPROM, not corrupted. I will read Flash and post it here.
check fuse ,relays, eis breacker and motor starter.......
Attached Flash., can someone confirm if it looks bad. and the new EEROM.
Seems like the EEPROM changed alot since the last time I wrote it. Maybe low battery EIS lost EEPROM data and not working?
A906 545 48 08 MC9S12DG256 FLASH Original.rar
possible,you have ori eeprom,, on w906 often ecu connector corrosion
Attached
Dodge Sprinter 2008 A906 545 48 08 Q01.rar
Contains Original EEPROM when I first Read it, then I used Tango and gave me file with Key #1. Also attached is the current EEPROM in the EZS.A906 545 48 08 MC9S12 EE SEC Original Read After Key #1.rar
skc say,dump no correkt
Dodge Sprinter Mercis - PCF7936 USA market
mercis (21st January, 2017)
sorry,newer seen Dodge sprinter
Sent Sprinter to Euro Car Specialists and he got it working. He said the EZS lost some data along with ECU. Not much info to know cause of problem.
Only thing I can think of is the battery being low, and customer trying to start car next day while low battery and data got lost.
