You have narrowed down all the obvious reasons the only one left is that the TV is not compatible with your Box and your not alone, have read other reports of Openbox type receivers not working with other brands of TV
So I've got a brand new Goodmans 59" Ulta HD - and my Openbox V8S looks stunning on it - the only problem is there is no sound to go with it - a problem for most telly lovers I'm sure you agree!
I've tried it on another TV, and it works fine... so I know it's not a faulty box. I've tried it with a different HDMI cable, and in different HDMI ports so I know it's not that either.
All the connections are in perfectly fine, couldn't be tighter. I've tried turning the box on first then the TV and the other way around. It's a wired connection the the modem, so although I doubt that would be the problem that theory can be knocked in the head.
The settings on the TV seem to be set up to suit the box and we have an android box which is set up just fine with a HDMI cable, crystal clear picture and sound.
Ray
Openboxes are know for not working full stop ...
