Results 1 to 14 of 14
    DK Veteran buga37's Avatar
    Apr 2010
    USA
    Default VOLKSWAGEN Factory OEM KEY FOB 5K0837202 A
    Does anyone know what smd part and value on the picture?
    Jun 2010
    In a van down by the river
    Sorry, this is the best picture I could take with my phone
    PM me your address and info and I can mail you this PCB
  3. The Following 2 Users Say Thank You to indienick For This Useful Post:
    buga37 (19th January, 2017), Demetrius (20th January, 2017)
    Apr 2010
    USA
    Quote Originally Posted by indienick View Post
    Could you measure the value please
    Jun 2010
    I am showing 556 nF. The part is so small, I hope my equipment measured it ok.
  6. The Following User Says Thank You to indienick For This Useful Post:
  7. #5
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by buga37 View Post
    next time be more carefully when you open that type of key and you will not do any damages
  8. The Following User Says Thank You to Maartinj For This Useful Post:
    buga37 (20th January, 2017)
  9. #6
    Jun 2010
    Honestly, for this PCB, that capacitor lifted off the PCB for me with tweezers. Did not even heat up. Minimal effort.
  10. The Following 2 Users Say Thank You to indienick For This Useful Post:
    buga37 (20th January, 2017), Demetrius (20th January, 2017)
  11. #7
    Apr 2010
    you don't need that component if you replace the transponder with a glass id48
  12. The Following 3 Users Say Thank You to dmp For This Useful Post:
    buga37 (20th January, 2017), indienick (20th January, 2017), p1et (20th January, 2017)
  13. #8
    Apr 2010
    USA
    Quote Originally Posted by dmp View Post
    that's what i thought,i have tested the remote and its working just fine.It wasn't a good idea to push the pin inside
    I appreciate everyone who responded
    I appreciate everyone who respondedI appreciate everyone who respondedI appreciate everyone who responded
  14. #9
    Maartinj's Avatar
    Nov 2010
    Poland
    push pin inside is only one solution,
    but to push it too much will destroy it as you see
    you need to push it just enaught and slowlelly and all is ok
  15. #10
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by Maartinj View Post
    No it's not. For the best solution look here:
    https://www.youtube.com/watch?v=5TKdNgv1Fgo
  16. The Following 6 Users Say Thank You to p1et For This Useful Post:
    bawareca (20th January, 2017), lush29 (21st January, 2017), newone (20th January, 2017), offsystem (21st January, 2017), scotlock (21st January, 2017), triak88 (20th January, 2017)
  17. #11
    Jun 2010
    that explains a lot.
    Every time I use these keys I use glass 48. And when I saw that
    some component near the original transponder coil are not even
    properly soldered to the PCB, I wondered "why do I never have
    problems with this key?"
  18. #12
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by p1et View Post
    sure, but then metal PIN will not keep both cover toogether , use glue ...... hate it
    this same you can say - use hamer or drill to get access to cluster ... why not just unlock screw slowelly
  19. #13
    Jan 2016
    Here is video with opening Maartinj way and you see that pin is higher than components on board and shouldnt damage anything if well pushed.
    I do it always with brutal method (it's quicker) and no problems after. Cover is tight and seats well.
    https://www.youtube.com/watch?v=V1snxXcUEXA
  20. #14
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by amigokola View Post
    open over 20 that keys , and never did any PCB damages, but always did very slow and carefully.
