search in doc of abrites where is stored backup maby U can backup ori eep content and program eeprom by desoldering and that will be everything
Hello guys,
With a friend of mine we did try to code an additional key to the immo (with ABRITES if i remember correctly my friend's tool) and what should have taken 5 mins went into a .DEF clocks cluster.. (we jinxed it by thinking out loud while writing back memory that we should have taken an eeprom dump before using anything, and 2 sec after that, BAM!)
Luckily the Immo is currently OFF and the car is drive-able (except the speed needle is completely haywire and mileage is constant, 0)
Car is A3 2005 make, 140 HP, TDI 2.0. Chassys type: 1K0 (WAUZZZ8P25Axxxxxx)
Mileage: 219240km/136229miles
Instruments are: VDO H73 0300, Rev: D06, Coding: 0004013
8P0-920-930 Q
Been told that I need a 'virgin' dash dump to try to get things back to normal.
Is it a lost cause?
Thank you.
hi
maybe help you
8P0 920930 F
8P0 920930 R
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
TethiS (20th January, 2017)
a bit odd replying to myself, but anyways
got 'lucky' and found a proper dump (that i attach here).8P0920930Q.zip
