Hello colleagues could help me with the radio code PANASONIC with EPROM 24c25 send the file and serial number
thank you very much
IMG_20170119_093437.jpg.
thank you very much
Try to read agin eeprom like 24C256
luis marin (27th January, 2017)
Chrysler [RE6]
S/N T M9 340 2 01013
Code = 9086
Car235 (21st January, 2017), luis marin (27th January, 2017)
Hello eprom reading 24c256 code thanks
[Quote = disparos; 2939120] Se puede tratar 0451
WBR [/ quote]
Hello friend that code is incorrect you think you would have another option to solve it thanks
1. try code 4263
2. why written 2 different vin ?
luis marin (27th January, 2017), shooting (24th January, 2017)
Friend the code is not right look what appears to me
The code is 100% correct for the radio label you have attached,
Model: P05091464AF
Code = 9086
The problem is that dump attached is for different radio - P05091465AE
https://www.carstereocode.com/unlock.php?id=4474
So, code for which radio are you requesting?
P05091464AF or P05091465AE ???
Write original dump in P05091464AF with serial T M9 340 2 01013 and enter the code 9086
You have code for P05091464AF already - 9086, but your dump is for P05091465AE.
Where is the dump for P05091464AF? Have you changed the dump?
1. download original vin car
2. try code 5900 and 3095
3. The possibility of load dump after failed attempts
