maybe steering motor.
common problem by mini 2007 and up.
if they reach 80000km and up the motor go tits up.
hi , i have a problem with the CAS of mini cooper r56 2007 , the car start good ,unlock and lock perfect work, but in the dashboard show me red steering wheel fault , i tried reset CAS but nothing change , i change the battery because i read is usually problem with old battery , any help ? i have the elv out and work fine , is only its show me the fault .
thank in avance
😀😀😀solved the problem , i was reseting the cas , and no the elv , when i reset the elv solved the problem , 🤗🤗🤗
I cross my fingers every time I touch a mini. Suchs pain in the tits.
nenadgorgi (20th January, 2017)
I think is the same sistem ,but i have delphi for diagnostic and its no reset the elv , only the cas
I have heard (Only heard) that it is possible to program a bmw smart key (e90 style) to a mini....remote will program but car wont start. I have no idea if that's correct or doable, just thought i would share the info
i understand they are the same system. what i am saying is, Mini cars are inexpensive, and BMW are expensive. In my area, a lot of the Mini's are owned by people that cannot afford to maintain them, and I hate touching them because they will come back a month later and say "my airbag light is on now" or "my A/C stopped working a month after you programmed the key".
bearheroes (27th January, 2017)
Professional BMW immo solutions
Macedonia is one and GREEK!!!
