Mitsubishi Outlander MMCS Map
Results 1 to 5 of 5
    Sep 2014
    Somewhere
    Default Mitsubishi Outlander MMCS Map
    Hi to all!
    I have a mitsubishi outlander year 2011 with MMCS ata hard disk and I want to update the maps.
    I've tried to unlock the HDD with xbox unlock CD and ata laptop but I didn't succeed because the BIOS does not recognize the HDD.
    So I have a few questions if someone can reply:
    1. In some laptops the HDD is not recognize? My laptop is TROSHIBA TECRA ASX.
    2. Is there a free solution to update the maps without unlocking the HDD? For example using a clone DVD map.
    3. Where I can find the new maps?
    Thanks!
    Jul 2009
    I akso seeking for a solution for map update
    Sent from my V9H using Tapatalk
    Jul 2009
    Any idea will be useful...
    Sep 2014
    Somewhere
    Here are some info that I have found about the unlock and map Update.
    Are some 2016 maps out there?
    MMCS-Update.rar
    Jun 2017
    Quote Originally Posted by Jashmine1983 View Post
    you need to disable the drive in bios first - what you're seeing is the effect of the bios trying to access the hard drive, failing, then disabling it
    iirc, yes - you can build an installation script based off a previously installed hard drive.
    hth.
    O.
