Hi, AVDI (original) fail to do this job car was 100542km i put 78000km it show correct but after some seconds it goes to 16008753km i try many times set without get but same first show good what i write, then after seconds 16008753km!! now im stuck in this horrible km value .
Best Regards
Bhat year car,
Trimis de pe al meu D6603 folosind Tapatalk
drive car ca 20 km aand programm again
maby your dash autorization out.Loock by diagnostiks live data autorization sulution.
What km show in EZS?
When see actual value in EZS nothing show anything .. tomorrow will try vvdi tool then report here back after all i have a good back-up of this car
off-course first i was send an email to simon-touch where i was purchase this tool but weekend may they reply on monday & i know answer do as manual said etc do & do & do again till works (like in past) ........
P.S. i try also digi clone but fail just show me required mileage for just some seconds and then 160xxxxxxx ...
Best Regards
Maybe if you put a can flilter!!
If i help, d'not forget to press thank button!!
Niaz (21st January, 2017)
Yes mate my last option is
Best Regards
Disconnect battery then drive 10km and try again
Niaz (22nd January, 2017)
No, newer sw version on this car. Avdi dont support the reflashing process on the version you have. Put can filter, and than do it again and it will stay what you wrote
Yes only can filter,or vvdi mb tool to rest km in ezs FSB3
DP4 work good with this car and motor ecu with smok
