1. FILE DOES NOT WORK OR UNKNOWN IN TO DOWNLOAD
2. PROPERLY WRITE THE DATA
epd1221 (26th January, 2017)
sorry try again
your file doesnt have crash data what error you are getting
If i helped you please press thanx
Getting front impact and front seat errors. I check all wiring looks good swap sensor. Clear file w software. Before i got f1-11 and f2-11. Due to crash . File posted is the one i clear i can post original file early on the morning
yeah post original files,, maybe you cleared to much,, some times these needs to be cleared twice if you used power tools to bolt down modules,,
heres original. sorry had internet problems
this is tested solution,,
if you still get same error you should look into whatever the code is or post here the codes,,
clear 77960te1a020.rar
