i realise theres a stack of threads on this issue and iv trawled through them all on many many websites.
i have recently refurbished my sbc pump (motor fault) and have been left with the fault code c235c.
from what i can gather this cant be cleared with xentry. Iv tried the method thats all over the web and the first line that has to be set to zero returns 'counter is active' instead of '0'
im not sure if this is where im going wrong or if there is no possible way with star.
The brakes bled fine and and work as they should, das reports the pump is operating ok. SBC hold is unavailable also.
Can anyone point me in the right direction or tell me what hardware i need to reset this error?
now resolved
How did you resolve it man?
i reset a few extra things in dev mode xentry. If you need any help drop me a pm
Hello I've Sent to PM Post for Solution
Please pm me the solution.
Can you PM me the solution, thank you
Can you PM me the solution too, thank you
hi can you pm me the soultion ....
As the threadstarter i have done brushes, bleeding, all pressures ok tried to change all (14) "DJ settings" in das dev, no luck, still c235c, Pm would be much apreciated, thanx in advance
Can you please PM me the solution, thank you
