Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Jan 2017
    Default mercedes w211 sbc fault C235C - solution
    i realise theres a stack of threads on this issue and iv trawled through them all on many many websites.
    i have recently refurbished my sbc pump (motor fault) and have been left with the fault code c235c.
    from what i can gather this cant be cleared with xentry. Iv tried the method thats all over the web and the first line that has to be set to zero returns 'counter is active' instead of '0'
    im not sure if this is where im going wrong or if there is no possible way with star.
    The brakes bled fine and and work as they should, das reports the pump is operating ok. SBC hold is unavailable also.
    Can anyone point me in the right direction or tell me what hardware i need to reset this error?
  2. The Following 5 Users Say Thank You to dddrrift For This Useful Post:
    atakan (26th June, 2021), clauberty (12th June, 2020), gokifly (30th January, 2019), marassa (8th March, 2017), Norbi91 (6th May, 2019)
  3. #2
    Jan 2017
    now resolved
    Nov 2015
    Malawi
    How did you resolve it man?
    Jan 2017
    i reset a few extra things in dev mode xentry. If you need any help drop me a pm
  6. #5
    DK Veteran ray978's Avatar
    Aug 2009
    Hello I've Sent to PM Post for Solution
  7. #6
    Jan 2010
    Estonia
    Please pm me the solution.
  8. #7
    May 2017
    Can you PM me the solution, thank you
  9. #8
    Top Poster Redas's Avatar
    Mar 2010
    Can you PM me the solution too, thank you
  10. #9
    Mar 2016
    ireland
    hi can you pm me the soultion ....
  11. #10
    Apr 2018
    EU
  12. #11
    Aug 2018
    Sweden
    As the threadstarter i have done brushes, bleeding, all pressures ok tried to change all (14) "DJ settings" in das dev, no luck, still c235c, Pm would be much apreciated, thanx in advance
  13. #12
    Junior Member ceron1977's Avatar
    Nov 2016
    POLAND
  14. #13
    Sep 2018
  15. #14
    May 2010
  16. #15
    Jul 2010
    Can you please PM me the solution, thank you
