4D 67 is the correct chip and your Toyota qwick reset orange dongle can program the key in a minute. You must program in a master first , a valet chip will not program I til it see a master first.
Hi friends
I have a Scion TC 2005, lost all key so i have read immobox 93C66, with AVDI in toyota special functions, i have dump tool option where i can select dump and it?s automatically recognized, i found option virgim/auto key registation and all these option say (first key inserted in ignition will be automatically programmed.
But i saw some differences between this dumps, someone have try this and worked!!!??
I have tried add this key, can someone tell if correct added, please!!
Car is so far...
Pg1-D2 LOCKED
Pg2-10 LOCKED
Pg3-369B6417 LOCKED
Cheers
Press "THANKS" button. just one click, CHEERS
electrones (28th January, 2017)
you need key with pg1 32/52.
pg1 30/B0 is id68.
did it work anyway?
doctore (23rd February, 2017), electrones (23rd February, 2017)
Thanks friend i found this transponder from a friend because i don?t have any here
Pg1-52
Pg2-2E
Pg3-8E753983
Resp-45F9AB B30048
Can someone add it for me please!!
CHeers
try and report please..
Scion-added-posistion2.rar
**If the car don't start try to bridge pin 4 and 13 for 40 minutes.
G'luck.
electrones (24th February, 2017)
Can someone check pelase if i add this key correctly
Pg1-32
Pg2-35
Pg3-F0A79016
Did you check the Ariel, is it alive?
ucokseparoh (24th February, 2017)
Scan the car mate.. may be the problem lies else where.
I believe key was added correctly.
Sent from my ASUS_T00F using Tapatalk
Yes ariel is ok, no doubt with new key added, security light is off but car still no work, try jump 4 and 13 for 40 min without successes
No other problem is immo probs, me too believe maybe transponder probs with new key added, security light is off but car still no work, try jump 4 and 13 for 40 min without successes, maybe someone can take a look in my dumps to check where is the fault
Thanks in advance
Cheers
I've tried to re-check your original file under different maker of Toyota and all ended up with the same generated-file as i gave you yesterday. Probably it needs to program the ECU as well as the dump is look alike a Toyota double storage system (though it slightly differ)
As far as my concern if the security light is OFF that means key is recognized by immo. Did you scan the car mate? what is the scan result?
I did a Fortuner sometimes ago which had a pretty much the same symptom like yours.. security light is OFF but car won't start or even crank. Apparently the problem at that time lies in the fuse box and starter-relay/wiring.
electrones (20th March, 2017)
ucokseparoh (21st March, 2017)
Could someone help with location of immo box on the SCION tc 2005??????? Please HELP
