Disconnect battery for 15min and try...
He intended to make a spare for the car then connected his SKP. Programming was all OK but now none of the smart-key works any longer. Car can not start and on dashboard it says "Smart key not found. Refer to handbook".
what can be done to help this friend guys?
every idea is highly appreciated.. thanks..
doctore (26th January, 2017), ucokseparoh (26th January, 2017)
Okay mate.. will tell it to him. Thanks.
He already did that. He even did it 30minutes,but result is the same. Car still can not start.
Sent from my ASUS_T00F using Tapatalk
if its had the update in the past couple of years then its off to the dealers for a big bill.... maybe try to find someone with a JLR Doctor to try that.
doctore (26th January, 2017), ucokseparoh (26th January, 2017), whiskeyman (26th January, 2017)
has it been to main dealer for a service or any work done at dealers or any recalls , if so then its had kvm update that prevents key programming by most equipment , avdi claim a solution as does jlr doctor from legend web
if going down dealer route id sit down when making that call
bawareca (28th January, 2017), doctore (26th January, 2017), kronk92 (27th January, 2017), obdsystems (29th January, 2017), phuckyall (3rd May, 2017), ucokseparoh (26th January, 2017)
May be it has had the update.. just did a bit search regarding that warn thrown by AD and find it out the cars that been listed as "dangerous" is 2013+
Due to circumstances beyond our control we are advising TCodePro & MVPPro users not to attempt to program proximity keys on Jaguar / Land Rover vehicles listed below. (with immediate effect)
JLR have identified a security vulnerability in the keyless ignition function and are now recalling all vehicles manufactured from 2013 to 2016 back to the workshop for a security update.
Attempting to program keys on these vehicles using ADS207 after the dealer update has happened permanently disables the proximity function and the KVM (Keyless Vehicle Module) must be replaced.
Land Rover Evoque 2013+
Freelander 2 2013+
Range Rover Sport 2013+
Range Rover 2013+
Discovery 2013+
Jaguar 2013 + All models
We are currently working on this issue and will advise of any changes.
The AD Team
CaioW (26th January, 2017)
i take year advice with a pinch of salt on cross over year.
Many people say me JLR from thelegend will repair kvm killed by skp.
with Tapatalk
Good to know, thanks for the info!
Just got an info that it actually can be fixed if we have the JLR online subscription (i don't know whether or not it's the same with JLR Doctor). Possibility with cracked soft is also opened. I got this info from a friend.. he said keys can be recovered..he had done many. He bases in UK.
doctore (26th January, 2017), ucokseparoh (27th January, 2017)
There are 2012 vehicles that have had the updated KVM units so the 2013+ statement is a bit misleading. If in doubt then check (bit late in this case), our local Land Rover dealer have been very helpful. Quick phone call to ask them to look up the vehicles service record and confirm if the update has been carried out. Not sure if all dealers are so helpful but worth a try.
been spoken about many times and many warnings
if you take word of dealer to say its ok then your brave man
prepare to get it right up the arse from dealer
