Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
ivaylo5225 (7th September, 2018)
I reprogrammed the eeprom and it accepted the pin you gave me, then I reset the new CIM and programmed it to the car with TECH2 successfully but now cannot program the keys. TEch2 says - invalid key. Do I need to buy new transponder chips PCF7946AT? or there is a way to program the old keys ?
You must buy a new PCF7946AT.
if fitting a replacement CIM and you use 'replace cim unit' in the immobiliser menu then you can use your existing keys from the car...
Can someone give me PIN please Vectra C CIM 93LC76
pin is 0357
accchris (8th October, 2018)
Sorted found it in SMOK
Hi i need the pin of the cim module. I do not know which of the two processors is why I upload both files
Thanks in advance.
Thank you very much
0437 is correct code for pro.222.bin
OK. It's there pin for pro.221.....
Give me PIN please Vectra C CIM 93LC76
