Results 1 to 11 of 11
    Sep 2015
    Default Zgemma h2s software problem
    Evening all.
    My box gives me a blue screen saying there's a software problem and reboots at precisely 21.09 each day.
    Not a massive problem but just wondering if anyone has an easy fix for this?
    P&D's Avatar
    If its doing everyday at the same time.....sound like something is trying to update
    I would uninstall any epg/Chanel list updater.....or go in to the setting see what program updates at 21.09
    Sorry i don't have one of these.....does this box have an error log list ? if so up load it i'm someone will point you in the right direction
    Sep 2015
    I think it might be something to do with the remnants of Crossepg being on my box, still crashing at the same time every day, Crossepg isn't in the list of plugins I can remove but the reference is still there on my list when I click on 'plugins.'
    If I select Crossepg it gives the same software error message and blue screen I get when it crashes each night
    Oct 2008
    ftp to the box and delete it regards jovie ps wot os are you using if its vix its the wrong os for zgamma
  5. The Following User Says Thank You to jovie For This Useful Post:
    pupuqiop (18th February, 2017)
    Sep 2015
    Thanks for the reply mate! I'm using openatv.
    What does 'ftp to the box' mean please?
    P&D's Avatar
    Quote Originally Posted by pupuqiop View Post
    oooooo.......dear......I'm guessing the box was setup for you by someone else then ?
    https://en.wikipedia.org/wiki/File_Transfer_Protocol
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Go to crossepg and check configuration as it sounds like where you are storing epg is full and needs deleted. {As jovie was explaining} Hopefully it's not stored to internal flash.
    Oct 2008
    you need to do a little reading its hard to explain but really easey wen you start to learn how, every thing you need is on this forum just search regards jovie
  10. #9
    Sep 2015
    Thanks for the replies everyone. I did set the box up myself but followed a step by step guide and the terminology never really stuck in my memory. I'll look into the things you suggested. Cheers for taking the time to help, much appreciated.
  11. #10
    Sep 2015
    By 'FTP it' do you mean access the zgemma box on the network from my pc, and then if I delete the folder named 'Crossepg' in the folder named 'harddisk' it'll remove it?
  12. #11
    Oct 2008
    yes thats right you need file zilla to access your box then search for the file make sure you get the right one, right click on it and
    the list will have delete in the list. you need the ip address of your box ,username is root password is password web control port 80
    ftp is 21 best of luck regards jovie
