Results 1 to 3 of 3
    Senior Member shankill2012's Avatar
    ULSTER
    Default L bracket not level
    Hi , My 1 metre motorised dish's L bracket is not level which stops me completing my "arc" , has anyone any ideas as to how I can lift it up and get it level again , I've some pics attached , thanks.
    P&D's Avatar
    put some spacers behind the bottom 2 bolts in between the plate & the brick
    or re drill it
    I would also check whether the L bracket is 100% vertical.....going off the brick work its leaning to the left
  3. The Following User Says Thank You to P&D For This Useful Post:
    shankill2012 (29th January, 2017)
    ULSTER
    I ended up fitting 24" T&K brackets and moving the dish onto them ( hard work on your own - up a ladder ! ) then took the L bracket down , I'm now getting the full arc with just a bit of tweaking to get maximum signals , great hobby this !
