Hello, could somebody clear the internal code from this steering angle sensor?
Thank you,
PN: 89245-74010
Chip: 93c66
89245-74010 steering angle sensor 850deg code 93c66b.rar
Thank you,
PN: 89245-74010
Chip: 93c66
br.balazs (25th February, 2017)
Abdo Abdelatif (24th May, 2018), BestElectrical (1st February, 2017)
Somebody took the wheel off to check the clock spring and turned the steering angle sensor more than 850 degrees so it is now stuck at 850. I have seen some people remove that code from dump and steering sensor worked after that fine. There is no problem with the sensor.
Thank you,
BE
You can try to remove the 4 bytes after "aa 55" in line 80
My last guess would be to also clear out the data in line A0 after the 2 bytes "aa 5a"
Sorry I can't be more helpful,
Good luck!
ahmad emamy (11th January, 2019), BestElectrical (1st February, 2017)
Any other ideas?
Yes can reset and corect errors
Sent from my F3216 using Tapatalk
Can you solve the problem ?
Or just use original dump and set the angle sensor closer to zero while cheking it on diagnostics
rtbdiagnostic (23rd August, 2019)
With original dump it is always showing 850.5 degrees. Even when it is straight at 0 degrees. Toyota sensors have a specific range, if exceeded that range the sensor writes error code inside eeprom and stops working. When the sensor is connected in the car and somebody is checking if the clockspring is good, they go over the range with a good clockspring killing the sensor.
PierreTheron (6th December, 2017)
Is it possible that the steering angle sensor physically broke, like how a clock spring can break by over turning? I have never taken a steering angle sensor apart on a Toyota before
BestElectrical (3rd February, 2017)
I fixed some before but older ones, none with 93c66 so far.
I don't have a clue on this one.. what year is this prius?
