CM871 TURBO ACTUATOR DELETE
Results 1 to 3 of 3
    Feb 2017
    Default CM871 TURBO ACTUATOR DELETE
    NEED ALL INFO I CAN GET ON DELETING TURBO ACTURTOR, ALREADY HAS DPF DELETED, NOW TURBO BLEW UP AND DRIVER WOULD LIKE TO PUT A REGULAR TURBO ON UNIT, NEED TO KNOW WHAT TURBO, AND OTHER PARTS NEEDED AND BEST WAY DO PERFORM DELETE
    Feb 2017
    depending on who did your delete you will only have a code for the inlet air temp sensor, if you get more, if i can remember off the top of my head there are about 4-5 parameters needed to be adjusted so ecm doesnt look for actuator, run an older style not egr turbo, aftermarket manifold, also should change the water pump to pre egr
    Nov 2017
    tn but originally from ny
    im looking for what parameters needed to be changed also for vgt delete on a cm871.. I got the tci temp sensor fault light off, just haven't figured the correct ones to set for vgt actuator driver circuit
