CFF/SMR-F FULL DATABASE for Vediamo/DTS Monaco - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 72
  1. #16
    Apr 2017
    Quote Originally Posted by autoparty1978 View Post
    hello i need full cbf for vediamo ?
    Just install Xentry. Than you'll have all CBF files from DAS & Xentry.
  2. The Following User Says Thank You to twingnu For This Useful Post:
    pmercury (9th April, 2017)
  3. #17
    Junior Member pmercury's Avatar
    Nov 2016
    aka BenzNinja
    thx, that is what I was doing
    I have das xentry 2016/9 but no offline
    so I am installing DAS.Xentry 12/2014-01-02/2015
    with the DAS Offline Programming Enable 12/2014 patch
    but my mus is like 6 month old and I get a
    Fault (1.18)-9.890
    dunno how to fix it
  4. #18
    DK Veteran cocutanu's Avatar
    Jun 2009
    I think you forgot to apply blacklist fix. If you have a SDConnect mux your mux was messed by Xentry. (you need hardware fixes for that).
    Hopefully you have PartD mux, this one is not affected on a hardware level but still need to install the blacklist fix for it.
  5. #19
    Nov 2016
    aka BenzNinja
    Quote Originally Posted by cocutanu View Post
    yes but it's a high quality partT C4 mux C4 works with T part
    and it's not messed up because when I use my 2016 Xentry disk with my D630 it works perfect
  6. #20
    Nov 2016
    aka BenzNinja
    also, the DAS.Xentry 12/2014-01-02/2015 I installed on another removable disk is a Acronis image
    I only needed to generate developper keys and it works
    I change partD to PartT
  7. #21
    Jun 2009
    In this case, then, you will need to "downgrade" the firmware version on your C4 mux to match the necessary version for your 12.2014. Usually, this step is done automatically once you are connected with your mux. If this step is not done yet then you should make it "manually" using the files provided in SDConnect Toolkit. My guess is that the original folders have been removed(renamed) from your Acronis image, a step which many users are doing to avoid upgrading their muxes "automatically".
    Beware that at this point, if you don't have a real HQ clone, your mux can be bricked.
  8. #22
    Nov 2016
    aka BenzNinja
    got it working with another 9.2014 DAS / bin folder for C4
    but finally couldn't get offline scn working
    so now i'm trying with xentry 2012.. it should just work fine with a developper key right ?
  9. #23
    GB
    do you have the latest for CTRLC205_Series_003 as the one I dont have the new variant. Its a 477 marco polo but using 205 structure.
    wbr
  10. #24
    Nov 2016
    aka BenzNinja
    Quote Originally Posted by tonyadams5 View Post
    wbr
    i don't understand ... what please ?
  11. #25
    GB
    I need cbf file for above unit
    Sent from my iPhone using Tapatalk Pro
  12. #26
    Apr 2017
    how to download plase
    happy Easter
  13. #27
    Apr 2017
    Hello
    Can You post file 1669027703_001.CFF and 2129022700.CFF
    plz.
  14. #28
    Jun 2016
    need updated software for these rear door modules on a w221 the numbers on the modules read this
    sw: A2214422132
    ps: A0054474632
    other one is the same
  15. #29
    Dec 2010
    Can you please post 0009035400_001.cff?
    Thank you!
  16. #30
    Feb 2017
    how can i get this or download
