Results 1 to 15 of 18
    Nov 2015
    Default ktm 990 zadi 1 add key to dump,please
    hello to all members please any one can help me add cn2 data to dump,in advance thanks
    richard27's Avatar
    Aug 2011
    hello you dump ??
    ​information sharing
  3. The Following User Says Thank You to richard27 For This Useful Post:
    Helvio91 (7th February, 2017)
    Nov 2015
    Please any dk member can help m add that key to dump?? Thank u in advance
    gepakg's Avatar
    Serbia
    you can add key to dump,but for every KTM you must get secret key for page 4 from your dump and write it to cn2,ys-01,tpx2,etc...
    not easy job as you think...
    also be care if you make master key possible to de-sync immo-ecu
    regards Gepa
    Quote Originally Posted by Helvio91 View Post
  6. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    chli1976 (8th February, 2017), doctore (8th February, 2017), Helvio91 (8th February, 2017)
    Nov 2015
    thank u master gepa
  8. #6
    Apr 2012
    London
    As Gepa said - do not try put master key into dump - You will lose synchro between ECU and Immobox and as a result Your bike become f...ed up
  9. The Following User Says Thank You to zyjekrc51 For This Useful Post:
    gepakg (8th February, 2017)
  10. #7
    gepakg's Avatar
    Serbia
    yes,that is bit dangerous thing,but also can be solved opening ecu Keihin (inside 93c56) and sync again
    mean can be maked second life for every dead on that point :-))))
    regards Gepa
    Quote Originally Posted by zyjekrc51 View Post
  11. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    doctore (8th February, 2017), Helvio91 (11th February, 2017), mohamedkey (17th November, 2018)
  12. #8
    Nov 2015
    DK masterS on ducati Hypermotard PIC18F6585 IS secured?thank u in advance
  13. #9
    gepakg's Avatar
    Serbia
    yes,in 90% cases secured
    regards Gepa
  14. The Following 3 Users Say Thank You to gepakg For This Useful Post:
    Helvio91 (11th February, 2017), mohamedkey (16th November, 2018), nhobe79 (24th June, 2018)
  15. #10
    May 2018
    morning i got ducati hyperstrada but pin page is not show on cluster any clue?
  16. #11
    May 2018
    Default ducati hypertrada
    hello all members any one can help me i need pin code from that file.thank u very much to all
  17. #12
    Sep 2012
    ecu Keihin (inside 93c56) any immo off plz
  18. #13
    gepakg's Avatar
    Serbia
    no immo off on that ECU,only virgin...
    regards Gepa
    Quote Originally Posted by mohamedkey View Post
  19. The Following User Says Thank You to gepakg For This Useful Post:
  20. #14
    Sep 2012
    vergine mean put FFFFF !!!! and dos the bike start !!!! need answer
  21. #15
    Sep 2012
    can i sync kawazaki ecu i mean this can happen with it
