Check power suply , grounds and can bus......
possible bad abs modulator also
Hello.have an audi a4 2009 8K model, with a steering angle defective error, and esp light on, of course.
If i want to do a basic setting, with security access i cant because the steering angle measuring, but after +172Grade jump to -172 and continue to+172 and to.
I replace with one othr but the dtc is the same
00778 - Steering Angle Sensor (G85)
014 - Defective
and measuring same with jump from+173 to-172
I tried with once another sttering angle senzor , but the problem is same.i can't make adaptation,
i have originalVCDS , updated to 17.1
So have somebody some advise what can i do?
Need some oher adaptation in other place?Need some procedure to adapt the angle senzor?
Thanks.
so here is the complet dtc
Address 16: Steering wheel Labels: 8K0-953-568.clb
Control Module Part Number: 8K0 953 568 F HW: 8K0 953 568 F
Component and/or Version: Lenks.Modul H12 0013
Software Coding: 000013
Work Shop Code: WSC 06335 123 12345
VCID: 3D71D5FBA43805A9E4-8068
1 Faults Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 128
Mileage: 233075 km
Time Indication: 0
Date: 2008.06.03
Time: 00:56:56
Freeze Frame:
(no units): 44.0
Text: 2C91FFFFFFFF00C0FF
Fuel Consump.: 650.3 l/100
Raw, Index/Key Err.: 255 255 000
Text: 3E7B000031393035FF
Mass Air / Rev.: 68.4 mg/str
Mass Flow: -12.81 g/s
Power supply checked, ca bus comunications is ok, the ground cable is good too, so i dont know how cant measure more than 172 grade +,-.
In ABS, i cant make basic setting for steering angle senzor, but in steering wheel i can....here a see that steering angle senzor is not initialized.
Have anybody changed steering angle senzor for this type of car before?Audi A4 2009.
Must do some other special procedure?
Thanks.
try odis had this problem before
Ill try.Thanks.But i dont understand why i can't do this with original vcds?
I have exactly the same problem - tried 3 different G85 and all of them in VCDS show:
014 - Defective
and all 3 of them work from 0 to +175 and them jump to -175 to 0
Hi.The problem was resolved by buying a new module by the dealer for customer.Thanks for answers.....
mexanico1971 (7th October, 2017)
Thanks. In my case first three G85 were defective. Fourth was a good one.
