Results 1 to 4 of 4
    Jul 2014
    Default MED 9.1 replaced - please help
    MED 9.1 ECU replaced on 2007 Passat. Old ECU no longer communicates via OBD2.
    I've copied the 95160 EEPROM to the replacement ECU. VIN and coding were transferred OK, but not component security, so car does not start (dash says "safe").
    MCU is MPC562MZP56 (image below)
    Anyone have pinout?
    Or any information on a cheap BDM programmer which will read/write this reliably?
    Or any other method to get this vehicle running with the replacement MED 9.1 ECU? Any help appreciated.
    Above sea-level
    You can use bdm100 to copy the ecu memories to another ecu.
  3. The Following User Says Thank You to budG60 For This Useful Post:
    raskolnikov1975 (5th October, 2017)
    Mar 2016
    Mexico
    i had teh same problem and i red it with galleto 4
  5. The Following User Says Thank You to Dasmech For This Useful Post:
  6. #4
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    It is best to use BDM. Or try making immo off in EEPROM if you need to ride.
  7. The Following User Says Thank You to raceshadow For This Useful Post:
