    Dec 2013
    N. Ireland
    Question Best skin for Zgemma H2S
    Have just received a H2S, and it has Q skin v1.6 (have seen 1.7 here), and IMO a little awkward to get around...not very intuitive, no PIP!
    Is there better, e.g. Slyk?
    And if so, how can i update, to either?
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Why not try the other skins, you can either install via the menu-plugins-down-Green Button-skins and install the skin you fancy then switch to that skin via menu-setup-usage&gui-skin setup.
    Or for skins not available in the github then these have to be install manually, have a look at Kiddac's webpage for the Slyk skin and others with instructions on how to install.
    https://slyk1hd.yolasite.com/
    PS. Don't think any skins have PIP
    Dec 2013
    N. Ireland
    Thanks, though sadly I have had to return my box as it didn't work thru TP links (homeplugs) [why i can't understand, but oh well].
    Yes, the Slyk skin looks better, was wanting someone to confirm such.
    Sorry, didn't mean PIP, but preview screen beside channel list (not sure what its called), though the Q skin on above box did have this, and online images show that Slyk does too.
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Don't give up with the Enigma 2 satellite box, could have been faulty box or compatibility issue between the homeplugs and the Zgemma, perhaps have a look at an Edision OS mini this has built in WiFi which will connect to your router with ease.
    Jul 2014
    Quote Originally Posted by martin035 View Post
    flash my image below m8 as the sly skin init
    Dec 2013
    N. Ireland
    NO, am intending to get a replacement Zgemma, and will confirm with vendor pre purchase if it works with homeplugs. Still trying to find out the best skin to get/use?
    Sorry fudge1, don't see anything there?!
