Results 1 to 3 of 3
    Mar 2013
    Default Zgemma Star S - sly skin and kodi
    Hi all
    Sorry lm a bit new to zgemma boxes so l just wanted to know if there is a sly skin for this box - zgemma star s....seen other versions for different boxes around but can't locate one for this box. And any help to install the sly skin file would be great. I have used the latest image of "openvix" (dated 2nd Oct 2016) from the zgemma website as l didn't like openatv. Unless there is a openvix version l can use with sly skin and kodi already available - then that's even better ! :-)
    Also any help with getting kodi running on here too would be gratefully received
    Thank you
    Charlie
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Follow the instruction/download on Kiddac's webpage to install the sly skin (either Original or Q version) on to your Zgemma S
    https://slyk1hd.yolasite.com/
    The Full version of Kodi doesn't work on a Zgemma box you have to use a lite version called Kodi direct, this is available from the menu-plugins-downloads but can be very hit or miss to whether the Stream will work, you're better off getting a cheap android box and running a full version of Kodi with associated plugins on that.
    Mar 2013
    Cheers l will give it a go :-)
