Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    Jun 2016
    Default Ford Fusion 2016 HS7T-14B321-AE Renesas R7F701A033
    Hi all,
    Could you help me clear crash data in this SRS unit FORD FUSION HS7T-14B321-AE
    MCU R7F701A033
    Thanks for help
  2. The Following User Says Thank You to Ringo24 For This Useful Post:
    Afreendalal (17th July, 2017)
  3. #2
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    I wish I could help you but I have not had any of these come in.
    What tool did you read this with? I think ETL and CarProTool have clear files for these that they give with purchase of the activations. I was hoping they all did, but must not.
    Jun 2016
    problem solved
    Aug 2014
    Nice. Any chance you could elaborate a little and share with us how you solved this one?
  6. The Following User Says Thank You to repairmymodule For This Useful Post:
    AUTODIAGNOZA (18th February, 2017)
    U.S.A
    got exactly same car with same airbag module,any updates what tool can read this renesas mcu ?
  8. #6
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    I think so need read flash and save, then clear eeprom and write back flash and done , but maybe I wrong ?
    Best regards.
    Dragon
  9. #7
    Jun 2016
    no. if you need solution I will send.
  10. The Following 4 Users Say Thank You to Ringo24 For This Useful Post:
    bermuxa77 (19th January, 2020), dragon100 (30th May, 2017), kosta89 (20th December, 2019), lwood (30th August, 2017)
  11. #8
    DK Veteran LockBit's Avatar
    CarProTool (cpt) can get clear file by cpt exe in realtime .
    Just click get clear file button and add crash file , next you have clear file read for write by cpt
  12. The Following User Says Thank You to LockBit For This Useful Post:
    Abdo Abdelatif (2nd December, 2017)
  13. #9
    Ringo24
    Can you send solution for this srs ecu?
    What tool You use for read/write MCU ?
    Thaks a lot
    B.R.
  14. #10
    Jan 2014
    Michigan State USA
    ETL from canada
    Mr. jerry
    buy the programmer and activation 500 us dollar???? not sure or $600
    will read 2017 fusion and 2016 Honda civic
    it is hardware module must solder pins on board
    or cpt programmer but not sure
    people they charge average $100-150 range to fix this new modules
    this is my feed back
  15. #11
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Default Tested Solution
    Tested solution guys.
    Included both Dirty and Clean files! PM for Pass.
  16. The Following 33 Users Say Thank You to slavax For This Useful Post:
    AUTODIAGNOZA (14th February, 2018), bermuxa77 (19th January, 2020), ChipGods (20th February, 2018), crackintosh (12th July, 2019), credoline (17th October, 2019), Dan007 (24th April, 2019), darktnt (9th January, 2020), den5 (7th November, 2019), dusiukas (29th January, 2018), FxShaw (31st January, 2018), georgije (18th November, 2019), gonzcaal (15th August, 2018), greencamp (5th January, 2018), harold1987 (13th August, 2018), hexguru (9th January, 2020), Inquizit0r (15th December, 2018), ivyura1977 (13th March, 2018), juozas10 (1st December, 2017), karzan1977 (10th April, 2019), long beach (26th March, 2018), luis12 (1st December, 2017), lwood (16th August, 2018), mcm44 (2nd December, 2017), mkopytekchi89 (3rd April, 2018), mrandrerio (10th April, 2020), natcorporation (8th May, 2018), repairmymodule (2nd December, 2017), samux (17th February, 2020), soploski (2nd May, 2020), supana (29th November, 2019), TJ007 (25th March, 2018), valdirld (1st December, 2017), websergei (30th January, 2020)
  17. #12
    luis12's Avatar
    Jan 2011
    Panama
    Friend wich programmer used ?, are BIN format ?.
  18. #13
    slavax's Avatar
    Sep 2016
    Soyuz 1
    I used CPT to download and clean the file. Both files in BIN format so you can compare them to see what lines to clear.
  19. The Following 2 Users Say Thank You to slavax For This Useful Post:
    crackintosh (12th July, 2019), eudes (4th July, 2018)
  20. #14
    Abdo Abdelatif's Avatar
    Aug 2013
    RENESES R7F.
  21. The Following 4 Users Say Thank You to Abdo Abdelatif For This Useful Post:
    Dan007 (24th April, 2019), natcorporation (8th May, 2018), TJ007 (25th March, 2018), valdirld (4th December, 2017)
  22. #15
    Feb 2018
    HI .
    CAN YOU SEND ME PASSWORD PLEASE.
    THANK YOU
