Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Jul 2009
    Default ford ranger 2016 model
    hello what eeprom this car uses this one dont uses 93C86
    i want to do mileage
    thanks in advance
    HELLO
    winaiservice's Avatar
    Oct 2015
    Have 93c86 and spc5606 mcu Ford ranger 2016
    Sep 2009
    Quote Originally Posted by mvtamele View Post
    thanks in advance
    It will be eepromless SPC5606s
    Sent from my SM-G935F using Tapatalk
    Don't forget to hit thanks button
  4. The Following User Says Thank You to javyb For This Useful Post:
    rtbdiagnostic (16th August, 2017)
    Nicolas9's Avatar
    Feb 2017
    Aruba
    x-tool can do ranger 2016 by obd
  6. The Following User Says Thank You to Nicolas9 For This Useful Post:
  7. #5
    May 2010
    Which x-tool can do 2016 ford ranger by obd, Thanks in advance
  8. #6
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    XTOOL X-100 Pro and X-100 Pad from Xtooltech
    'If I helped, please click Thanks +Reputation.. !'
  9. #7
    Sep 2009
    Quote Originally Posted by rtbdiagnostic View Post
    XTOOL X-100 Pro and pad from Xtooltech
    No it can't. If ranger has a screen either side of dash it's 93c86
    Sent from my SM-G950F using Tapatalk
  10. The Following 2 Users Say Thank You to javyb For This Useful Post:
    rtbdiagnostic (18th February, 2020), waylyn (16th August, 2017)
  11. #8
    May 2010
    it's a 93c86 screen either side.
  12. #9
    May 2015
    My Tool Room
    Quote Originally Posted by waylyn View Post
    looks like this maybe ?
  13. #10
    May 2010
    Yep, thats the one
  14. #11
    May 2015
    My Tool Room
    what tool you recommend for 2017 ford everest with 93c86 cluster
  15. #12
    Jan 2016
    i tried ranger 2017 and read ok, but dash died after try change. battery disconnect and back to life
  16. #13
    May 2015
    My Tool Room
    Quote Originally Posted by javyb View Post
    Can I open cluster and remove 93c86 chip from back read and write and solder back to board
  17. #14
    May 2015
    My Tool Room
    sagie as per your picture (SPC5606S)Continental cluster have done this 100% success with x-100 pro xtooltech use menu New Mondeo small colour screen - have you done the cluster with 2x lcd on both sides yet see picture SPC5606S + 93c86 Denso ? Advice will be appreciated
  18. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    sagie (24th September, 2018)
  19. #15
    Jan 2016
    i have not done one yet but you must remove 93c86 chip and use ford mustang soft
