Results 1 to 9 of 9
    Aug 2011
    Default DM800HD PVR IP problem !
    Dear Friends,
    I can not connect my DM 800 to the computer via IP address, Is there any guidance or any solution ?
    But, it can be connected to the network via that IP address and run the xxxxx.
    Aug 2011
    I think, I need to install Web interface with DCC, but, how ???
    toysoft's Avatar
    Nov 2008
    Flash a proper new image, as all these things should work. So press the frontpanel button when you turn on the box until you see on the LCD the IP Address, then flash an image that is compatible with your sim in the box, and all will work again.
    TS
    Aug 2011
    I did, but, still cant get connection with browser to flash a new image !!
    Quote Originally Posted by toysoft View Post
    TS
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Have you checked the IP address is correct? Power off, back on holding the power button until 'stop' appears. Then try connecting to the ip address displayed on LCD
    Aug 2011
    Yeah, I know the IP address of the box and i set it manually with no DHCP !!
    Its all about the Webinterface , I think, I removed it !!
    Quote Originally Posted by cunny View Post
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by fahimjan View Post
    Then check in the pluggins page. If nto there either download it again or flash a new image
    toysoft's Avatar
    Nov 2008
    The Webinterface in the image has NOTHING to do with the Flashing of the box.
    And to successfully flash the box YOU MUST set both cables, RJ45 + RS232 (REAL), and use a DHCP or something similar (Fixed IP set by your router), as the ROUTEUR must give an IP Address to your box and it must show up on the LCD.
    Only then you will be able to flash your box properly,
    TS
    Jul 2016
    If you have a doubt on the web interface you can try an FTP client like filezilla and connect to the box only using ftp protocole.
