Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Jul 2020
    Hy Chris!
    I tried to read the code without the card and with the ignition off, no luck, the same ISK code is retrieved and wrong PIN..
    About the translation, thank you for your work, but unfortunately i can't reach the point where i inser the APV code because simply I can't calculate it properly..
  2. #32
    Sep 2020
    Le havre
    Quote Originally Posted by tomalamix View Post
    Hy Chris!
    Hi, and using Manal request carefully, maybe you can read the APV (pin) code.Manual request.JPG
  3. #33
    Jul 2020
    Hy Chris,
    No luck, I went to the menu you said but all i got is zeros 00000
  4. #34
    kiszka's Avatar
    Hy Chris,
    you are unlucky enough to have 00000000
  5. #35
    Jul 2020
    Hello Kiszka,
    You know what it could be? maybe a bad EOBD cable? I can do all other things with it, no complaints, but still it is an old unit bought from the usual Chinese stores..
  6. #36
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I use oblink ex original . Never had problem . Maybe you got issue with interface
    Here to HELP!
  7. #37
    Jul 2020
    I have a K-line cable, but i think DDT4All doesnt work with it, or it does?
    I think it only works with DDT2000, right?
