Programming key Renault!
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Feb 2017
    Default Programming key Renault!
    Hello all people who are reading this.
    I have a Renault Espace 2005.
    I have lost the keys to the car.
    I have bought a blank keycard to be programmed and USB TO ODB cable
    What software can i use to program the key to the car i hope somebody can help me on this one
    Thanks in advance!
    Feb 2017
    Or if anybody Has the download link to DDT2000 light version
    doctore's Avatar
    Nov 2015
    Colorado Denver
    go to the nearest locksmith and l let you program the card
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  4. The Following User Says Thank You to doctore For This Useful Post:
    autochei (20th February, 2017)
    Dec 2010
    UK
    Quote Originally Posted by stunter23 View Post
    Thanks in advance!
    Just using a obd / usb cable will not do it.
    Normally the programs/ softwares that will do it will cost 100's of pounds if not more and come with own cables.
    its cheaper to go to the local locksmith and pay them to code it in for you as doctore said above.
  6. #5
    Feb 2017
    Where i live there is no locksmith i live in the netherlands.
    I have seen you can program key with DDT2000 light version it is freeware but i don't know where to find it.
    Does anybody have a clue where i can find DDT2000?
  7. The Following User Says Thank You to stunter23 For This Useful Post:
    mustafabahar (3rd June, 2017)
  8. #6
    Feb 2017
    Or if anybody knows how i can get the pin/secuirity code to program a key.
    The pin code reader does not work for my renault espace does anybody know how i can get this code because i also have an other tool to program key but asks for pin code.
  9. #7
    Jul 2013
    Scotland. UK
    If you can get it working....
    DDT2000 is old software, and many functions on the lite version aren't working. Not even sure 'lite' will even do the key programming bit. Sure it just does fault code testing. Then there's the issue with your pin code... which you probably don't have, and don't know how to get.
    Plus your USB>OBD cable will most likely be a K-line interface, which'll talk to older Renault models but for CAN (like your 2005 Espace) it probably wont connect.
    Call an expert. Someone will 100% come to your part of the Netherlands and program for you. probably cost about €60.
  10. #8
    Jun 2013
    The Netherlands is such a small country anyway.
    Maybe 2,5 hours driving from top to bottom?
    Or crossing the country should take about 70-80 minutes?
    This calculation is without traffic jams involved.
    And the roads are also of high standard.
    I am quite sure that there will be a locksmith within that range.
    A locksmith will be at your location real rapid.
    They are used to drive larger distances, to get some of their hard earned income.
  11. #9
    Apr 2010
    Gdansk Poland
    fvdi, carprog clip. buy som of those tools and program key
  12. #10
    solitaire's Avatar
    May 2010
    LT, jonava
    best tool for renault key programming: Reanult CAN/K-line ECU Tool
  13. #11
    Dec 2016
    February, 2017 I was in hibernation like the snake !!!!
    DDT2000 LIGHT ( only use it ! ) :
    https://mega.nz/#!XMsUCZxJ!QdS80KT4B...rtb3vkPgkgSr3U
    Registration to paste in C:\Program Files\DDT2000\dll :
    https://mega.nz/#!LdclxDCJ!2MOPF5w6Z...aeqwbwGvPU9TRg
    DATABASE To merge in C:\DDT2000data :
    https://mega.nz/#!WI0H2IwL!4NmtVyKa4...eLgA9SQW2DwhZY
    RPE2 for ISK TO PIN & key learning request !
    Very easy in all car with "KWP2000" protocol ; use KKL VAG-COM 409.1 OBD
    FOR OTHER CAR USE OBDLINK SX + RENOLINK (including RPE3 by OBD2) SOFTWARE ( not free activation but "YES I CAN" pm )
    https://mega.nz/#!Pdk10ArC!rg4CE0J_498Q6i2O7NRBCdqe_nHEzg7kyzhg2gR 4yqo (No antivirus to open !)
    Renault pin extractor 2 ;
    https://mega.nz/#!bAlSgDLJ!r-XW5zSiu...5Lz13IQOK_6EiU
    ALL MEGA link AVAILABLE only 1 MONTH
  14. The Following 5 Users Say Thank You to TERMINATOR1000 For This Useful Post:
    amaflo (7th June, 2017), dmerkovic (13th August, 2019), just4upal (29th June, 2017), rob h (3rd June, 2017), T2000 (22nd March, 2019)
  15. #12
    Apr 2017
    Quote Originally Posted by Weasel3 View Post
    The are more than 50 locksmith the can do your Renault key
    Verzonden vanaf mijn iPhone met Tapatalk
  16. #13
    Nov 2014
    hi can you post the links for ddt2000 again please? i had it years ago but that hard drive packed up, just got another renault and need to get my codes
  17. #14
    Jan 2019
    Hello Terminator 1000,
    looks like you are one of the few people who know what they do.
    I have a problem which it looks like you know a solution for
    I also have Renault 2 Ph 2, Kid lost our last key ;(
    I found the ISK, but can't find the correct PIN.
    ISK CODE: 15A9936B6377
    (61 AB 01 AC 61 95 38 00 00 00 00 00 00 00 00 00 00 00 00 15 A9 93 6B 63 77 14 72 2E 1D 36 27 A1 42 A9 27 0D 60 BF A1 42 A9)
    Could you help me to generate the right PIN?
    I also have Renault Pin extractor to change ISK to PIN but maybe program is old, because it gives me wrong PIN.
    Once you got the right PIN, which program did you use to program the key? I don't have ZetBull.
    I only have DDT4ALL.
    Can this work?
    Thank you very much in advance!!!
    T
    PS: I'm not sure which UCH is in my car, I guess Siemens 9366, but I don't know how to find out.
  18. #15
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by T2000 View Post
    Can this work?
    T
    You will tell us what kind of time machine you are in for repair
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
