I can't flash my DM8000_Ferrari
Results 1 to 3 of 3
    Oct 2016
    Default I can't flash my DM8000_Ferrari
    Hi, as the title says, I can not flash my dreambox.
    I have already tried several browsers, and nothing works. After choosing the image file or even just the SSL to send, does nothing. stay still...
    I have also tried dreamup, with several, ferrari, JapharFlasher, and others ... nothing ...
    Us that does something, it stops at: "uploading flash loader" ...
    I was told to send SSLferrari87F first, I already have the file but I can not send it ... is there another way to send it? With DCC, for example, does it work?
    Has anyone had this problem?
    @Fainas
    Oct 2016
    Hello, I've been able to solve it!
    Yes I could connect with dreamup but it would stop.
    With the help of a friend, we tested several things and with the NFI image tools plugin, I was able to flash.
    The plugin flashes directly from the enigma2. Then as the image I tested had SSL76, it returned to the same.
    But by the same way I installed SSL87F and now it is already working normally, I can already flash through the browser.
    Should be because of SSL76. That is, I already know what the problem is.
    thank you,
    @Fainas
    did you try the null modem cable are did you fix it another way what image did you manage to find was stable
    regards Stagie
