Peugeot 307 - need PIN
Results 1 to 8 of 8
    May 2010
    Default Peugeot 307 - need PIN
    Hi friends. I need PIN (BSI is bricked) VIN : VF33ANFUC82188300.
    kiszka's Avatar
    Aug 2009
  3. The Following User Says Thank You to kiszka For This Useful Post:
    szantis (25th February, 2017)
    May 2010
    Quote Originally Posted by kiszka View Post
    read eeprom ECU or BSI
    of vin, only service peugeot
    Ok , i have dump from old BSI.
    ee pug 307 ori.zip
    Jul 2012
    Netherlands
    Yor file seems to be virgin, there is 0101010101010101010101010101010101 VIN number...
    Try to read eeprom from engine ECU
  6. The Following User Says Thank You to massiwe For This Useful Post:
  7. #5
    May 2010
    Ok i Have now eeprom from ECU. Maybe now we get PIN UWL7???
  8. #6
    Jul 2012
    Netherlands
    Your PIN UWL7
  9. #7
    Jul 2012
    Netherlands
    You can make your BSI vergin with this file and with your PIN code it should be possible to reprogram old keys as well
  10. The Following User Says Thank You to massiwe For This Useful Post:
  11. #8
    May 2010
    Thanks , I have used "new" BSI with virgin HC912 , i need only pin to add key Now i think i have all
