wbart (18th January, 2018)
dpf off vag siemens ppd
sw 6576286545
upg sw 03g906018dn 4350
engine r4 2.0l ppd1.2
MB Sprinter 2.2 CDI Ecu Delphi CRD3 2013
it´s possible egr off? I need help please.
Would be grateful for your help; DPF & EGR off
Nissan NV200 diesel turbo
Delphi DCM3.4
Thanking in advance
Please help! +more fuel(~110mm3!?) 2000-5000rpm and popcorn! Very-Very thanks!!!
Opel Astra H 1.9cdti 8V 120ps, EDC16C9
Anyone able to make a launch control with this rev limit and exhaust pops? Or have a stage 1 file with all that? Thanks!!
Or just exhaust pops??
E39 523iA M52TU with MS42
Hello dear ACE Tuning
i have one Renault Lodgy with Delphi ECM DCM3.4
237102575R
237104028R
i want to speed limit off or if possible i want to make its speed and mileage boost ,
here is the file
i taken with kess v2
any one help me out
can someone tell me what I have to do to get the speed limit to vw vento 2.5 5 cylindersI thank you very much! regards
NEED HELP SIEMENS SID803 EGR OFF 5WS40281A-T
Can someone help me to remove EGR on siemens SID803 and make checsum of need
I tried with professionnnal egr off software and did not work car start 5 second and stop
I writed bak original file and ca start but with egr problem
Here is mpc file
Thanks a lot
can some one help me to remove my EGR whit the conector unpluged ? it is an Opel corsa c 1.2
Bosch bosch me 1.5.5
hi, i need 25-30hp for megane III 1.5dci 82kw sid305
can anyone help me..
30 36 34 36 52
0646RE4BE0037R
46918PLANTECOS_
00000FFOIX
thanks!
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
bonjour les amis voila jai une Brera 2.4 jtdm 210 cv de 2009 dans le mode dégradé, adaptent le changement DPF / FAP, EGR, volets enlevés, DTC, désactivez le lambda et plus de puissance pour mon 2.4L 20V JTDM 154 kilowatts / 207 CV EDC16 + Protocole de déviation du fichier: FLASH_0076 FAL BOSCH EDC16 + de Numéro: 0281014459 ::: Je suis en mode dégradé Je suis en panne j'ai modificateur suprimer cata fab erg et il faut desactiver les deux sondes et ocmenter la puissance et til passable merci a vous
