Page 59 of 219 FirstFirst ... 949545556575859606162636469109159 ... LastLast
Results 871 to 885 of 3273
  1. #871
    Jul 2017
    Quote Originally Posted by dannyanto9292 View Post
    Hi i have edited the egr hysteresis map and removed the insufficient flow egr dtc, I would like +10% more power but don't have the knowledge/confidence to do so, I have included both the original map I read from the car via mpps + the map which I have edited egr on, your help is much appreciated thanks.
    vw golf mk5 1.9 pd bkc 105hp
    03G 906 016 CB
    028 101 190 0
    EDC16u1
    Stage 1 + egr off.
    Pass PM.
    BR
  2. The Following User Says Thank You to kalisiux For This Useful Post:
    dannyanto9292 (12th November, 2018)
  3. #872
    Hi nissan pathfinder ,
    Stage1 from 50% and kore pedal
    Eco until 50%.
    Can u?
  4. #873
    Nov 2018
    Moldova
    Помоги пожалуйста...нужен damos file для Rover 75 2.0 CDT Bosch DDE 4.0
  5. #874
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    Quote Originally Posted by Sergiu0203 View Post
    this is an English only forum, if theres any more posts in any language other than English they will be deleted !!!
    Oct 2018
    Zafira B ori eep.rarHi!
    Can you help me with PIN CODE for Zafira B IPC ECU (Instrument Control Unit)?
  7. #876
    Jan 2018
    Default need egr off land rover evoque sd4
    hi can anyone help me for egr off ecu EDC17C42 LAND ROVER EVOQUE SD4
  8. #877
    Nov 2018
    Moldova
    Help to disable the EPP and add power at least 15% rover 75 2.0 cdt, bosch dde 4.0 ... maybe you have a damos file
  9. #878
    Newbie wepster1979's Avatar
    Apr 2017
    uk
    Hi!
    Can U help with egr off please please please?
    Thank you!! (volvo v60 2.0 diesel 2011)
  10. The Following User Says Thank You to wepster1979 For This Useful Post:
    OriginalG (16th November, 2018)
  11. #879
    May 2018
    Serbia
    Hi all!I need tune file for BMW X3,2005,HW Bosch 0281011564,SW Bosch 1037361894,Bmw HW id 07796571,Bmw Sw id 07794145
    THANKS IN ADVANCE
  12. #880
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by vladar1 View Post
    THANKS IN ADVANCE
    I hink something is wrong with your file !
    I am not sure ,but i have done this ecu and i already have this mood done ,but your file donsent mach to original and mood !
    Trimis de pe al meu SM-G960F folosind Tapatalk
  13. The Following User Says Thank You to DR Race For This Useful Post:
    vladar1 (7th December, 2018)
  14. #881
    Mar 2013
    Random
    Please can u give some more power to A6 BRE engine.
    THX! 391846
  15. #882
    Jun 2018
    Solihull
    Hi!
    Canyouhelp me with EGR OFF for Landrover Disco SID204?
    I tried to use EGR Remover 2017 - but the engine did not started at all8((
    I install EGR plates.
    So here is original flash,
    Thank you.
  16. #883
    Usa
    Default Hi Please DPF Off
    Hi, I need DPF OFF...
    L200 4D56 DENSO RHF4 SH7059 MITSUBISHI 2.5L
    Thank You.
  17. #884
    Feb 2018
    turkıye
    benim için bu dosyayı egr dtc kapalı yaparmısın teşekkürler dtc code p 0403 marelli mjd ecu http://dosya.co/v8x1ko2jugbl/52aak448_albea_orjin.html
  18. #885
    gmb45's Avatar
    Nov 2008
    English only
