Page 31 of 219 FirstFirst ... 2126272829303132333435364181131 ... LastLast
Results 451 to 465 of 3273
  1. #451
    Jun 2013
    Poland
    Quote Originally Posted by teamtuner View Post
    bad read.........
    read bdm better ........
    read by ktag
  2. #452
    johak's Avatar
    Apr 2010
    here you go
  3. The Following User Says Thank You to johak For This Useful Post:
    wbart (18th January, 2018)
  4. #453
    Feb 2017
    england
    Default a3 dpf off plese
    dpf off vag siemens ppd
    sw 6576286545
    upg sw 03g906018dn 4350
    engine r4 2.0l ppd1.2
  5. #454
    Jun 2017
    Default MB Sprinter 2.2 CDI Ecu Delphi CRD3 2013 egr off
    it´s possible egr off? I need help please.
  6. #455
    Jan 2011
    Would be grateful for your help; DPF & EGR off
    Nissan NV200 diesel turbo
    Delphi DCM3.4
    Thanking in advance
  7. #456
    Oct 2017
    Please help! +more fuel(~110mm3!?) 2000-5000rpm and popcorn! Very-Very thanks!!!
    Opel Astra H 1.9cdti 8V 120ps, EDC16C9
  8. #457
    Jan 2018
    Anyone able to make a launch control with this rev limit and exhaust pops? Or have a stage 1 file with all that? Thanks!!
    Or just exhaust pops??
    E39 523iA M52TU with MS42
  9. #458
    Jun 2016
    Hello dear ACE Tuning
    i have one Renault Lodgy with Delphi ECM DCM3.4
    237102575R
    237104028R
    i want to speed limit off or if possible i want to make its speed and mileage boost ,
    here is the file
    i taken with kess v2
  10. #459
    Jun 2016
    any one help me out
  11. #460
    May 2017
    argentina
    can someone tell me what I have to do to get the speed limit to vw vento 2.5 5 cylindersI thank you very much! regards
  12. #461
    securipro38's Avatar
    Feb 2010
    EU
    NEED HELP SIEMENS SID803 EGR OFF 5WS40281A-T
    Can someone help me to remove EGR on siemens SID803 and make checsum of need
    I tried with professionnnal egr off software and did not work car start 5 second and stop
    I writed bak original file and ca start but with egr problem
    Here is mpc file
    Thanks a lot
  13. #462
    can some one help me to remove my EGR whit the conector unpluged ? it is an Opel corsa c 1.2
    Bosch bosch me 1.5.5
  14. #463
    Apr 2016
    hi, i need 25-30hp for megane III 1.5dci 82kw sid305
    can anyone help me..
    30 36 34 36 52
    0646RE4BE0037R
    46918PLANTECOS_
    00000FFOIX
    thanks!
  15. #464
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by securipro38 View Post
    Here is mpc file
    Thanks a lot
    securipro clean your PM
    your egr off disconected from plug
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  16. #465
    Jan 2018
    belgique
    Default alfa brera
    bonjour les amis voila jai une Brera 2.4 jtdm 210 cv de 2009 dans le mode dégradé, adaptent le changement DPF / FAP, EGR, volets enlevés, DTC, désactivez le lambda et plus de puissance pour mon 2.4L 20V JTDM 154 kilowatts / 207 CV EDC16 + Protocole de déviation du fichier: FLASH_0076 FAL BOSCH EDC16 + de Numéro: 0281014459 ::: Je suis en mode dégradé Je suis en panne j'ai modificateur suprimer cata fab erg et il faut desactiver les deux sondes et ocmenter la puissance et til passable merci a vous
