Here this dpf off Toyota !
DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etcDo not forget to press the button thanks and reputation
# Algerian #
hi I need chiptuning please, egr dpf off is possible
BMW E46 318i M43b19 O2 sensor bank 1 sensor 2 off is possible?
https://www95.zippyshare.com/v/kHLRIG8U/file.html
Can you disable stop start in my file? Golf VI 1.6 TDI CR CAYC 03L906023MN
solved .
Hi everyone !
i only need DTC
hello, great concept this
can anyone please help or are these ECUs to hard to work with?
have 318i BMW 1999 with the BMS46 ECU.
thr engine needs more mid range torque and a 7,000 RPM
the torque limiter id think is an issue?
thankyou
kind regards
Ryan Williams
hello, need dpf off toyota avensis 2006 2.0d4d.
read by ktag
Vagabond90 (14th April, 2021)
Hi! Need a DPF and EGR OFF.
Alfa 159 1.9 JTDm 16V 150HP 0281013138 1037389889
HW: 0281013138
SW: 1037389889
VIN nr.:
SW ver.:
Spare: 51812906
Engine:
HW Ver.:
SW upg.:
Installation:
Sirius83 (15th October, 2018)
Thnks! But remover 2017.05 It`s not good solution for EDC16C39
jen1k (17th October, 2018)
