what is problem with ABS (codes etc) probably have to calibrate SAS
If i helped you please press thanx
You need to go into ABS module with scan tool and goto Special Functions and perform Lateral Sensor Calibration, Longitudinal Calibration and YAW Sensor Calibration .
If any of those fail during calibration, you need better clear. You can always try codecard automatic online crash cleaner (?30)...
chiorbeq (24th February, 2017), DOUGLASDL (24th February, 2017), Frankcar (24th February, 2017), ReverseFlash (24th February, 2017)
I get what you're saying, but calibrating lat, long, and yaw sensors doesn't work, that's the first thing I did. After restoring original file, the abs problem with U code invalid data received from restraint control module went away. Basically I flashed it with a good file, but I guess that file is different.
If anyone can help me clear the crash data without flashing entire file, that be great ��. CodeCard online clearner is great, but I thought I'd try DK forums first.
Solved, no longer neee help.
why you do not post what you did,that next time people could help you again when you needed,
i hope u understand my point
Dear ReverseFlashi have the same problem, can you tell me how to solve that problem, please.....
