Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 93
Thread: 35160WT erase
  1. #16
    All your Tools, don't work with 35160....
  2. #17
    Also it is no good to fill with ffff it needs to be 0000
  3. #18
    Rito's Avatar
    Quote Originally Posted by diagtech View Post
    Yes I mistake says FF, It is 00 in all 4 lines... And done erase WQ160....
  4. #19
    Mar 2011
    Vilnius,Lithuania
    it's not the same 160DWQ and 35160WT . what car you did ?
  5. #20
    35160WT currently not possible to erase
    Sent from my SM-G950F using Tapatalk
  6. #21
    Apr 2013
    What about Smok ?
  7. #22
    Apr 2013
    What about Smok ?
  8. #23
    kachimbi's Avatar
    Oct 2012
    Hey , i also have R270 andd it erases that eeprom.
  9. #24
    Apr 2013
    Problem is not erasing. Tamper dot will apear on dash.
  10. #25
    Oct 2017
    Can I use my R270 to only erase/blank the vin on 35160WT? Mileage is ok, just need to clear the VIN. Do I have to desolder the EEPROM first?
  11. #26
    You should always remove eeprom as for vin it should be ok to change as it will not be in the secured part of the eeprom
  12. #27
    Nov 2017
    Shenzhen
    35160WT new BMW dashboard use
    Can not erase
    Workaround: Use the new IC
  13. #28
    brend's Avatar
    Oct 2015
    Same where
  14. #29
    Nov 2017
    Shenzhen
    Yes, I know
    Some people use emulator
    But the emulator price is high, the tool price is also high
    New IC, you can not write ID
    Maybe, there will be red dot
  15. #30
    brend's Avatar
    Oct 2015
    Same where
