    Canada
    Default 2010 e350 benz no sound from speakers any idea help
    hello members
    got 2010 e350 with issue no sound coming from speakers,, any ideas or help is appreciated
    here are the codes i get ,, amp ad head unit already been replaced,, can someone point me in right direction please
    If i helped you please press thanx
    Oct 2016
    check for water damage in the trunk and floor...inspect plugs for corrosions or rust. had this issue before...turned out to be water leaking into trunk or floor.
    Canada
    clean dont see no water damage,,
    Feb 2013
    usa
    does it have a cd changer had one go bad once it was befor the amp in the circuit also make sure no speaker is shorted that will make the sound go off
    Canada
    replaced the amp,, now i can activate nd hear sound from speakers but still no music needs to write vin in amp i suppose gives me code vin mismatch
    Mar 2016
    South Africa
    is ur problem fixed yet
