Results 1 to 3 of 3
    Dec 2015
    Default zgemma s2 openvpn
    Hi all,
    I installed open vpn and set it up, activated all seems well I've checked ip and itsee using my server ip, but when I reboot the box it sticks at 49 on boot anybody know what's going on?
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    If the box boots OK without the open vpn plugin then it sounds like the plugin is causing the problems, if using Openatv try doing a software update first before installing the Open vpn plugin and see if that makes a difference, if you're using a differnce firmware then ensure it's fully upto date.
    Don't forget to Backup all important files first
    Dec 2015
    Thanks for your reply I did an update and it's working, sadly the update did kinda break everything 212 updates I was using your image.
