ZGEMMA full specs for each and every box please,
Results 1 to 2 of 2
    Mar 2017
    Default ZGEMMA full specs for each and every box please,
    Edited as nobody was able to produce full spec breakdown for ZGEMMA, Info found on openpli wiki, Note Zgemma is found halfway down the list, hope this helps others out.
    After reading the full spec breakdown i opted for the Mutant HD51 being a 4k box with a healthy 1.7 ghz cpu and double ram to the Zgemma,
    Also the ability to change out the tuners and add in more tuners, I am now able to have dual sat + dual cable in one box
    SET-TOP-BOX COMPARISON
    In the table below you will find most of the STB's supported by OpenPLi, with their technical specifications, real power consumption figures, and the OpenPLi version supported for the model. Please note that this list shows only relevant differences between STB's. Features that are shared by all (like digital S/PDIF audio out) are left out.
    VU+
    STB Model Zero SoloSE Solo2 Duo2 Uno4k Solo4k
    Type STB *A Zapper Zapper PVR PVR PVR PVR
    OpenPLi
    Support status 4 4 4 4 4 4
    Tuners
    Fixed / pluggable 1/- -/1 2/- -/2 -/1 1/1
    Fixed tuners (single/dual) *B 1xS - 2xS - - -
    Fixed tuners (FBC) - - - - - S
    Pluggable tuners (single/dual) - S/C/C+T - S/C/C+T S/C/C+T S/C/C+T
    Pluggable tuners (FBC) - - - - S/C+T -
    Media
    Other manufacturers remote control - - - - - -
    CI - 1 1 2 1 1
    Smart card 1 1 2 2 1 2
    HDMI 1 1 1 1 1 1
    HDMI-CEC + + + + + +
    Component video - - - + - -
    Scart - - 1 1 - -
    LNB pass-through - + - pluggable pluggable pluggable
    Cable pass-through - - - - pluggable pluggable
    User interface
    HBBTV / browser + + + + - -
    Display 1 LED 1 LED VFD text VFD 140x32 - LCD 480x320
    Miscellaneous interfaces
    Ethernet Mbps 100 100 1000 1000 1000 1000
    USB 2.0 host 2 2 3 3 2 (2xSS) 3 (2xSS)
    Storage
    Harddisk internal *C - - 2.5" 2.5/3.5" - 2.5" bay
    Harddisk external *C - + - + - -
    Other memory - - - - - -
    Internal
    SoC bcm7362 bcm7241 bcm7356 bcm7424 bcm7252s bcm7376
    Architecture mips32el mips32el mips32el mips32el armv7ahf-neon armv7ahf-neon
    CPU Mhz 742 1300 1300 1300 1700 1500
    Cores 1 1 1 1 2 2
    Threads 2 2 2 2 2 2
    RAM total MiB 512 1024 1024 2048 2048 2048
    RAM available MiB 570 965 214
    Flash size MiB 256 256 (512) 256 1024 4096 (eMMC) 4096 (eMMC)
    Video resolution HD-p HD-p HD-p HD-p UHD UHD
    Transcoding *D - limited limited + + +
    PiP *E - full full full full full
    HEVC decoding in DVB - - - - + +
    HEVC decoding in media - - - - + +
    Linux kernel 3.13 3.13 3.13 3.13 3.14 3.14
    Delayed decoding - - - - - -
    Demuxers (all/CA) 9/9 13/13 14/14
    OSD layer HD HD HD HD HD HD
    Power
    Active 9 W 16 W
    Stand by 8 W 14 W
    Miscellaneous
    additional colour LCD colour LCD + live view
    *A PVR means fully-featured recording settop-box, Zapper means watching only, no recording, no streaming.
    *B The vendor may sell both single and dual tuners, so there may be one or two tuners in one slot.
    *C This excludes USB harddisks, because they can always be connected regardless. Connectors are (e)SATA unless otherwise noted.
    *D Limited transcoding means: only one (small) resolution, quality is poor. Standby means: only operable in standby.
    *E Limited means: SD full motion and HD I-frames only (pictures gets updated 1-2 times a second)
    Zgemma
    STB Model Star S Star 2S Star H1 Star H2 H.S H.2S
    Type STB *A PVR PVR PVR PVR PVR PVR
    OpenPLi
    Tuners
    Fixed / pluggable 1/0 2/0 2/0 2/0 1/0 2/0
    Fixed tuners 1xS 2xS 1xS/1xC 1xS/1xC+T2 1xS 2xS
    Available pluggable tuners B - - - - - -
    Media
    Other manufacturers remote control + + + + + +
    CI - - - - - -
    Smart card 1 1 1 1 1 1
    HDMI 1 1 1 1 1 1
    Composite video + + + + + +
    Scart - - - - - -
    LNB pass-through - pluggable - - - pluggable
    Cable pass-through - - - - - -
    User interface
    HBBTV / browser *1 *1 *1 *1 *1 *1
    Display 4x7segment 4x7segment 4x7segment 4x7segment 4x7segment 4x7segment
    Ethernet Mbps 100 100 100 100 100 100
    USB 2.0 host 2 2 2 2 2 2
    Storage
    Harddisk internal *C - - - - - -
    Harddisk external *C - - - - - -
    Other memory - - - - SD SD
    Internal
    SoC bcm7358 bcm7358 bcm7358 bcm7358 bcm7362 bcm7362
    Architecture mips32el-nf mips32el-nf mips32el-nf mips32el-nf mips32el mips32el
    CPU MHz 750 750 750 750 750 750
    Cores 1 1 1 1 1 1
    Threads - - - - 2 2
    RAM total MiB 512 512 512 512 512 512
    RAM available MiB
    Flash size MiB 256 256 256 256 256 256
    Video resolution HD-p HD-p HD-p HD-p HD-p HD-p
    Transcoding *D - - - - - -
    PiP *E - - - - - -
    HECV decoding in DVB - - - - - -
    HECV decoding in media - - - - - -
    Linux kernel 4.0.1 4.0.1 4.0.1 4.0.1 4.0.1 4.0.1
    Delayed decoding + + + + + +
    Demuxers (all/CA) 7/7 7/7 7/7 7/7 8/8 8/8
    OSD layer 720 720 720 720 HD HD
    Power
    Active
    Stand by
    Miscellaneous
    STB Model H.2H H5
    Type STB *A PVR PVR
    OpenPLi
    Support status 4 4
    Tuners
    Fixed / pluggable 2/0 2/0
    Fixed tuners 1xS,1xC+T2 1xS,1xC+T2
    Available pluggable tuners *B - -
    Media
    CI - -
    Smart card 1 1
    HDMI 1 1
    HDMI-CEC + +
    Component video + +
    Scart - -
    LNB pass-through - -
    User interface
    USB 2.0 host 2 2
    Storage
    Other memory SD SD
    Internal
    SoC bcm7362 bcm73625
    CPU Mhz 750 750
    Cores 1 1
    Threads 2 2
    RAM available MiB
    Transcoding *D - -
    PiP *E - -
    HEVC decoding in DVB - SD/HD
    Demuxers (all/CA) 8/8 8/8
    OSD layer HD HD
    Power
    Active
    Stand by
    Miscellaneous
    *1 Using OpenOpera browser, not supplied by the manufacturer, not supported, not tested, no guarantees.
    Golden Media Golden Interstar Xpeed LX
    STB Model Class S2 Class C
    Type STB *A PVR PVR
    OpenPLi
    Support status 4 4
    Tuners
    Fixed / pluggable 1/- 1/-
    Fixed tuners S C
    Media
    CI - -
    Smart card 1 1
    HDMI 1 1
    HDMI-CEC
    Component video - -
    Scart - -
    Cable pass-through - +
    User interface
    Display 2 leds 2 leds
    USB 2.0 host 1 1
    Storage
    Other memory - -
    Internal
    SoC bcm7362 bcm7362
    CPU Mhz 750 750
    Cores 1 1
    Threads 2 2
    RAM available MiB 240 240
    Transcoding *D - -
    PiP *E - -
    Linux kernel 3.18 3.18
    OSD layer HD HD
    Power
    Active
    Stand by
    Miscellaneous
    XTrend
    STB Model ET7000 ET7500 ET8500 ET10000
    OpenPLi
    Tuners
    Fixed / pluggable 1/- 1/1 -/4 -/4
    Fixed tuners S S - -
    Available pluggable tuners *B - S/C+T S/C+T S/C+T
    Media
    Other manufacturers remote control - - - +
    CI 1 1 1 2
    Smart card 1 2 2 2
    HDMI 1 1 1 1 out / 1 in
    HDMI-CEC + + + +
    Scart - - - 1
    LNB pass-through - pluggable + +
    User interface
    HBBTV / browser *1 *1 + +
    Display 2 LED VFD text LCD tv output VFD 128x32
    Ethernet Mbps 100 100 1000 100+1000 *2
    USB 2.0 host 2 2 3 5
    Storage
    Harddisk internal *C - 2.5" 2.5" 3.5"
    Harddisk external *C + + + +
    Internal
    SoC bcm7362 bcm7362 bcm7241 bcm7424
    CPU Mhz 750 750 1300 1300
    Cores 1 1 1 1
    Threads 2 2 2 2
    RAM total MiB 512 512 1024 2048
    RAM available MiB 248 248 300 1257
    Flash size MiB 256 256 512 1024
    Transcoding *D - - - +
    PiP *E - - + +
    Linux kernel 3.14 3.14 3.14 4.01
    Delayed decoding - - - +
    Demuxers (all/CA) 7/7 8/8
    Power
    Active 14 22.4
    Stand by 13 3
    Miscellaneous
    *2 The ET10000 has two ethernet ports, the 1Gbps port does not function correctly on many of them
    Edision
    STB Model OS mini OS mini+ OS mega
    OpenPLi
    Tuners
    Fixed / pluggable *2/- 1/- 3/-
    Fixed tuners *2 S2/S/T2/T/C 2*S2+S2/S/T2/T/C
    Available pluggable tuners *B - - -
    Media - -
    CI - - 1
    Smart card 1 1 1
    HDMI 1 1 1
    HDMI-CEC + + +
    Scart - - -
    LNB pass-through - - -
    User interface
    Display 4x7segment VFD (8 digits) VFD (12 digits)
    Ethernet Mbps 100 *3 1000 *3 1000 *3
    USB 2.0 host 2 2 3
    Storage
    Harddisk internal *C - - +
    Harddisk external *C - - +
    Other memory - - -
    Internal
    SoC bcm7362 bcm73625 bcm73465
    CPU Mhz 751 751 1600
    Cores 1 1 1
    Threads 2 2 2
    RAM available MiB 568
    Flash size MiB 512 512 512
    PiP *E - - +
    HEVC decoding in DVB - SD/HD SD/HD
    HEVC decoding in media - SD/HD SD/HD
    Linux kernel 4.9.0 4.9.0 4.9.0
    Demuxers (all/CA) 5/5 5/5 7/7
    OSD layer HD HD HD
    Power
    Active
    Stand by
    Miscellaneous
    *2 There are 4 different hardware models: 1 x DVB-S2, 1 x DVB-T2, 2 x DVB-S2, 1 x DVB-S2 + 1 x DVB-T2
    *3 Embedded 802.11n Wifi interface, Embedded Bluetooth interface
    Xsarius
    STB Model FusionHD FusionHD SE
    Type STB *A PVR PVR
    OpenPLi
    Support status 4 4
    Tuners
    Fixed / pluggable 2/- 1/1
    Fixed tuners C+S S
    Available pluggable tuners *B - S/C/C+T
    Media
    CI 1 -
    Smart card 1 1
    HDMI 1 1
    HDMI-CEC - -
    Component video - -
    Scart - -
    Cable pass-through + pluggable
    User interface
    Display 3 leds 3 leds
    USB 2.0 host 2 2
    Storage
    Harddisk internal *C 2.5" 2.5"
    Other memory -
    Internal
    SoC bcm7362 bcm7362
    CPU Mhz 750 750
    Cores 1 1
    Threads 2 2
    RAM available MiB 237 237
    Transcoding *D - -
    PiP *E - -
    Linux kernel 4.2.1 4.2.1
    OSD layer HD HD
    Power
    Active
    Stand by
    Miscellaneous
    Formuler
    STB Model Formuler F3 Formuler F4 Formuler F4turbo Formuler F1
    OpenPLi
    Tuners
    Fixed / pluggable 1/- 1/- 1/1 2/1
    Fixed tuners S S S S
    Available pluggable tuners *B - - C/T S/C+T
    Media
    CI 1 1 1 1
    Smart card 1 1 1 2
    HDMI 1 1 1 1
    HDMI-CEC + + + +
    Component video + + - +
    Scart - - - -
    LNB pass-through - - pluggable pluggable
    Cable pass-through - - pluggable pluggable
    User interface
    HBBTV / browser - - - -
    Display LED 4x7 seg LED 4x7 seg LED 4x7 seg VFD text
    Ethernet Mbps 100 100 100 1000
    USB 2.0 host 2 3 2 3
    Storage
    Harddisk external *C - - - +
    Other memory SD SD SD
    Internal
    SoC bcm7362 bcm7362 bcm73625 bcm7356
    CPU Mhz 750 750 750 1100
    Cores 1 1 1 1
    Threads 2 2 2 2
    RAM available MiB 314 314 512
    PiP *E - - - +
    HEVC decoding in DVB - - + -
    Linux kernel 4.01 4.01 4.01
    Power
    Active 6.9 13.5
    Stand by 9
    Miscellaneous
    Mut@nt
    STB Model HD51 4K HD500c HD1200 / 1265 HD1500 HD2400
    OpenPLi
    Tuners
    Fixed / pluggable -/2 1/- 1/- 2/- -/4
    Fixed tuners - C S S -
    Available pluggable tuners *B S/C+T+T2 - - - S/C/C+T
    Media
    CI 1 - - 1 2
    Smart card 1 1 1 1 2
    HDMI 1 1 1 1 1 in/1 out
    HDMI-CEC + - + + +
    Component video - - - - +, rev2 -
    Scart AV AV 1 - 1
    LNB pass-through + - - + +
    Cable pass-through + - - - +
    User interface
    HBBTV / browser - *1 *1 *1 *1
    Display VFD 12segment LED 4x7 seg LED 4x7 seg LED 4x7 seg OLED 256x64
    Ethernet Mbps 1000 100 100 100 1000
    USB 2.0 host 2, 1x USB3 1 1 1 3
    Storage
    Harddisk internal *C 2.5" - - - 2.5"
    Internal
    SoC bcm7251s bcm7581 bcm7362/73625 bcm73625 bcm7424
    Architecture armv7ahf-neon mips32el-nf mips32el mips32el mips32el
    CPU Mhz 1700 750 750 750 1300
    Cores 2 1 1 1 1
    Threads - - 2 2 2
    RAM total MiB 1024 256 512 512 2048
    RAM available MiB
    Flash size MiB 4096 128 256 256 1024
    Video resolution UHD-p HD-p HD-p HD-p HD-p
    Transcoding *D - - - - +
    PiP *E + - - - +
    HEVC decoding in DVB + - 1200:-,1265:+ - -
    HEVC decoding in media - - - - -
    Linux kernel 4.7.4 4.7.4 4.7.4 4.7.4 4.7.4
    Demuxers (all/CA) 14/8 7/7 8/8 8/8 8/8
    OSD layer HD 720 HD HD HD
    Power
    Active 12/9 5.0
    Stand by 6 6.6
    Miscellaneous
    Max digital (end-of-sale models)
    STB Model XP1000
    Type STB *A PVR
    OpenPLi
    Support status 4
    Tuners
    Fixed tuners S
    Media
    CI 1
    Smart card 2
    HDMI 1
    HDMI-CEC +
    Component video -
    Scart 1
    LNB pass-through -
    User interface
    HBBTV / browser *1
    Display -
    Ethernet Mbps 100
    USB 2.0 host 1
    Storage
    Other memory -
    Internal
    SoC bcm7358
    CPU Mhz 500/600/750
    Cores 1
    Threads -
    RAM total MiB 512
    RAM available MiB 230
    Flash size MiB 128
    Transcoding *D -
    PiP *E -
    Linux kernel 4.01
    Delayed decoding +
    Demuxers (all/CA)
    OSD layer 720
    Power
    Active 10
    Stand by 8
    Miscellaneous
    Mut@nt (end-of-sale models)
    STB Model HD1100
    Type STB *A PVR
    OpenPLi
    Support status 4
    Tuners
    Fixed tuners S
    Media
    CI -
    Smart card 1
    HDMI 1
    HDMI-CEC +
    Component video -
    Scart 1
    LNB pass-through -
    User interface
    HBBTV / browser *1
    Display -
    Ethernet Mbps 100
    USB 2.0 host 1
    Storage
    Other memory -
    Internal
    SoC bcm7358
    CPU Mhz 500/600/750
    Cores 1
    Threads -
    RAM total MiB 512
    Flash size MiB 128
    Transcoding *D -
    PiP *E -
    Linux kernel 4.01
    Delayed decoding +
    Demuxers (all/CA)
    OSD layer 720
    Power
    Active
    Stand by
    Miscellaneous
    XTrend (end-of-sale models)
    STB Model ET4000 ET5000 ET6000 ET6500 ET8000 ET9000 ET9200 ET9500
    Type STB *A PVR PVR PVR PVR PVR PVR PVR PVR
    OpenPLi
    Support status 4 4 4 4 4 4 4 4
    Tuners
    Fixed / pluggable 1/- 1/- 1/- -/1 -/3 2/- 2/- -/2
    Fixed tuners S S S - - S S -
    Available pluggable tuners *B - - - S/C/T S/C/T - - S/C/T
    Media
    Other manufacturers remote control + + + + + + + +
    CI - - - - 2 2 2 2
    Smart card 2 2 1 2 2 2 2 2
    HDMI 1 1 1 1 1 1 1 1
    HDMI-CEC + + + + + + + +
    Component video - + + + + + + +
    Scart 1 1 1 1 1 2 2 2
    LNB pass-through - + + + + + + +
    Cable pass-through - - - - - - - -
    User interface
    HBBTV / browser *1 + + + + + + +
    Display - - - VFD text VFD text VFD text VFD text VFD text
    Ethernet Mbps 100 100 100 100 1000 100 100 100
    USB 2.0 host 2 3 3 3 3 3 3 3
    Storage
    Harddisk internal *C - - - 2.5" 3.5" 3.5" 3.5" 3.5"
    Harddisk external *C - - - - + - - -
    Other memory - - - - - - - -
    Internal
    SoC bcm7358 bcm7413 bcm7413 bcm7413 bcm7241 bcm7413 bcm7413 bcm7413
    Architecture mips32el-nf mips32el mips32el mips32el mips32el mips32el mips32el mips32el
    CPU Mhz 500/600/750 400 400 400 1300 400 400 400
    Cores 1 2 2 2 1 2 2 2
    Threads - - - - 2 - - -
    RAM total MiB 512 256 512 512 1024 512 512 512
    RAM available MiB 290 495 290 290 290
    Flash size MiB 128 128 1024 512 128 256 1024
    Video resolution HD-p HD-i HD-i HD-i HD-p HD-i HD-i HD-i
    Transcoding *D - - - - - - - -
    PiP *E - limited limited limited + limited limited limited
    Linux kernel 3.8 3.8 3.8 4.01 3.8 3.8 3.8
    Delayed decoding + + + + + + + +
    OSD layer 720 720 HD HD HD HD HD HD
    Power
    Active 10 35 16 28 26-50
    Stand by 5 12 23 21
    Miscellaneous
    VU+ (end-of-sale models)
    STB Model Solo Duo Uno Ultimo
    OpenPLi
    Tuners
    Fixed / pluggable 1/- 2/- -/1 -/3 *1
    Fixed tuners 1xS 2xS - -
    Available pluggable tuners *B - - S/C/T/C+T S/C/T/C+T
    Media
    CI 2 2 2 2
    Smart card 1 2 2 2
    HDMI 1 1 1 1
    HDMI-CEC + + + +
    Component video 1 1 - +
    Scart 1 2 1 1
    LNB pass-through - - + +
    User interface
    Display - VFD text VFD text VFD text
    Storage
    Harddisk internal *C - 3.5" 2.5"/3.5" 2.5"/3.5"
    Harddisk external *C - + + +
    Internal
    SoC bcm7325 bcm7335 bcm7413 bcm7413
    CPU Mhz 333 400 400 400
    Cores 1 1 2 2
    Threads - - - -
    RAM total MiB 256 384 512 512
    RAM available MiB 109 135 270
    Flash size MiB 128 128 128 1024
    Video resolution HD-i HD-i HD-i HD-i
    PiP *E - - limited limited
    Linux kernel 3.9.6 3.9.6 3.9.6 3.9.6
    Demuxers (all/CA) 5/5 9/9
    OSD layer 720 HD HD HD
    Power
    Active 20 22 33
    Stand by 17 16 31
    Miscellaneous
    WLAN 802.11n USB dongle
    *1 Only one of the pluggable tuners may be a dual tuner, bringing the total possible to 4 tuners.
    Dream Multimedia (end-of-sale models, no longer supported)
    Note that OpenPLi has stopped with all active support for hardware from
    Dream Multimedia. Newer models, including dm500hd v2, dm800se v2, dm7020hd v2 and
    the dm7080hd will not receive support from OpenPLi due to DMM closing up their
    sources. Please see the official OpenPLi statement on the homepage
    Support for these end-of-sale models is "as-is". Other than the OpenPLi version listed in
    the table, there will be no further development for these STB's.
    STB Model DM8000 DM500HD DM800SE DM7020HD
    OpenPLi
    Tuners
    Fixed / pluggable 2/2 1/- -/1 -/2
    Fixed tuners 2xS 1xS - -
    Available pluggable tuners *B S/C/T/C+T - S/C/T/C+T S/C/T/C+T
    Media
    CI 4 - - 2
    Smart card 2 1 2 2
    HDMI 1 (DVI-to-HDMI required!) 1 1 1
    HDMI-CEC - + + +
    Component video + - - -
    Scart 2 1 1 1
    LNB pass-through pluggable - + pluggable
    User interface
    Display OLED graphics - OLED graphics colour OLED graphics
    USB 2.0 host 3 - 2 3
    Storage
    Harddisk internal *C 3.5"+DVD - 2.5" 3.5"
    Other memory CF - - -
    Internal
    SoC bcm7400d2 bcm7405 bcm7405 bcm7405
    CPU Mhz 400 400 400 400
    Cores 2 1 1 1
    Threads 2 - - -
    RAM total MiB 256 256 256 512
    RAM available MiB 146 132
    Flash size MiB 128 64 64 1024
    PiP *E full - - limited
    Linux kernel 3.2 3.2 3.2 3.2
    Demuxers (all/CA) 5/4 5/4 5/4
    Power
    Active 31
    Stand by 27
    Miscellaneous
    Internal PCI WLAN adapter 802.11bg
    DTS Passthrough S/PDIF
    Software DTS downmix
    Software DTS downmix Software DTS downmix Software DTS downmix
    Dream Multimedia (end-of-life models, no longer supported)
    STB Model DM800HD
    Type STB *A PVR
    OpenPLi
    Support status 2.1
    Tuners
    Fixed / pluggable -/1
    Fixed tuners -
    Media
    CI -
    Smart card 1
    HDMI-CEC -
    Component video -
    Scart 1
    LNB pass-through +
    User interface
    HBBTV / browser -
    Ethernet Mbps 100
    USB 2.0 host 3
    Storage
    Other memory -
    Internal
    SoC bcm7401
    CPU Mhz 300
    Cores 1
    Threads -
    RAM total MiB 256
    RAM available MiB 180
    Flash size MiB 64
    Transcoding *D -
    PiP *E -
    Linux kernel 2.6.18
    Delayed decoding -
    Demuxers (all/CA) 4/4
    OSD layer 720
    Power
    Active
    Stand by
    Miscellaneous
    SoC does not support MPEG4-VC
    Last edited by openboxtiny; 13th March, 2017 at 02:15 AM. Reason: Updated info offered
    digicon's Avatar
    The only difference between the H version and the newer H5 version is the capability to use the H.265 codec
