HI YOUR CLEAR
GOOD LUCK
HI YOUR CLEAR
GOOD LUCK
markgal251 (12th March, 2017), tmkz (11th March, 2017)
Here are the files........
Hi, I also have a Peugeot 207 and need to clear the crash data , Can i do this with the file with the willam eprogger or is there another device i have to use.
Sorry i just tried to open the tar file and it's password protected .
Hi do you have clear crash data for my dump please.
Bosch .0 285 010 112
96 635 934 80 - 00
Eprom 95160.
Your file ... many topic for one srs unit mate come on ...
Best regards.
Dragon
markgal251 (30th March, 2017)
I am sorry i am doing this from mobile and started eeprom 95160 after ours to see if anybody had a similar problems with it Thank for your help i will try you file and report back.
No , dragon sorry used that last clear you sent , still the same.
Which errors in srs unit after clear ? Write here ...
Best regards.
Dragon
You mean re read eeprom now and post to you .
No, You need read errors from srs unit via diagnostic equipment, maybe some elements are bad, do you change bad elements (airbags, pretensioners ) ?
Best regards.
Dragon
I have just put my Autel maxiscan OBD ll on it and no error codes at all, And i haven't changed pretensioner,s
No errors and srs light on ?
Best regards.
Dragon
Yes no errors and the airbag or seatbelt pretensioner fault flashing on dash and airbag symbol lit below speedometer. Also passenger front seatbelt stays lit red even with seatbelt plugged in and sat in it .
