Vu + duo screen starting
Results 1 to 15 of 30
    Aug 2015
    Default Vu + duo screen starting
    I have problem with vu+ duo clone
    The screen stays in starting and from there it does not happen add the CFE to 3.0 but it stays the same
    Someone can help me thank you very much
    DK Veteran shaunfree's Avatar
    Nov 2008
    lancs
    flash the cfe first then add the image for your clone second cheers shaun
    Aug 2015
    Ok i have managed to put a blackhole image and it has started well
    The problem is that when setting the tuner is blocked and does not respond
    Nov 2008
    lancs
    you mean you cant configure tuner cheers shaun
    Aug 2015
    Is configured well but when exiting the menu the decoc
    Aug 2015
    BlackHole-2.1.4-vuduo_usb_wIPTV_List_Ferrari_Vall
    This image I have installed
    Nov 2008
    lancs
    not 100 % but think BlackHole-2.1.4-vuduo_usb_wIPTV_List_Ferrari_Vall is just for iptv and cant use tuner cheers shaun
    Nov 2008
    lancs
    try this BH image BlackHole-2.1.0.1-bm750…rrari_V2. https://mega.nz/#!p9hRRQSI!8wmYdybkc...8EB7zrfJkSEyfU
    cheers shaun
    Aug 2015
    I tried it but the dec? stays in Starting and does not start
    thank you very much for your help
    Nov 2008
    lancs
    did you flash the cfg first then image
    Aug 2015
    What is CFG I do not understand?
    Could you explain how I should solve this, thank you very much.
    Nov 2008
    lancs
    sorry mate typo error meant to mean cfe
  13. #13
    Aug 2015
    This log is with all images that is left in starting
    CM73350010
    012
    Shmoo Version=1.9
    MEMC-00000000 RW=00000011 WW=00000049 G=00000001 R=00000008 W=00000016
    MEMC-00000001 RW=00000010 WW=0000004F G=00000001 R=0000000A W=00000005 #$
    3
    COPY CODE
    A567
    BCM97335B0 CFE v2.17, CFE core v2.12, Endian Mode: Little
    Build Date: Thu Sep 29 12:01:32 2011 (shcheong@ncsh)
    Copyright (C) Broadcom Corporation.
    writing vfd
    !!!!! UNC read error occurred, while reading from NAND flash
    DDR Freq: 395MHz
    CPU speed: 405MHz
    Memory Config: 32+16 non-UMA
    Device Tech: 1Gb
    Total memory: 384MB
    Boot Device: NAND
    ECC: Hamming
    Total flash: 128MB
    Initializing USB.
    USB: Locating Class 09 Vendor 0000 Product 0000: USB Hub
    CFE initialized.
    checking usb
    Loader:elf Filesys:raw Dev:flash0.kernel File: Options:rootfstype=jffs2 root=/dev/mtdblock0 rw mem=0x8000000 bcmrac=3
    Loading: !!!!! UNC read error occurred, while reading from NAND flash
    0x80001000/8067328 0x807b2900/161408 Entry address is 0x805fd2a0
    TP1 Entry Address at 0x80000ffc = 805fd2a0
    Starting program at 0x805fd2a0
    Linux version 3.9.6 (dark@openspa.webhop.info) (gcc version 4.9.2 (GCC) ) #2 SMP Sun Nov 22 16:15:06 CET 2015
    Fetching vars from bootloader... found 11 vars.
    Early serial console at MMIO32 0x10400b00 (options '115200n')
    bootconsole [uart0] enabled
    Options: sata=1 enet=1 emac_1=1 no_mdio=0 docsis=0 pci=1 smp=1 moca=0 usb=1
    Using 256 MB + 128 MB RAM (from CFE)
    bootconsole [early0] enabled
    CPU revision is: 0002a044 (Brcm4380)
    FPU revision is: 00130001
    Determined physical RAM map:
    memory: 10000000 @ 00000000 (usable)
    bmem: adding 118 MB RESERVED region at 138 MB (0x07600000@0x08a00000)
    Zone ranges:
    Normal [mem 0x00000000-0x0fffffff]
    Movable zone start for each node
    Early memory node ranges
    node 0: [mem 0x00000000-0x0fffffff]
    Primary instruction cache 32kB, VIPT, 2-way, linesize 64 bytes.
    Primary data cache 64kB, 4-way, VIPT, cache aliases, linesize 64 bytes
    PERCPU: Embedded 7 pages/cpu @81204000 s6400 r8192 d14080 u32768
    Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
    Kernel command line: bmem=118M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
    PID hash table entries: 1024 (order: 0, 4096 bytes)
    Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    __ex_table already sorted, skipping sort
    Memory: 130944k/262144k available (6165k kernel code, 131200k reserved, 1464k data, 300k init, 0k highmem)
    Hierarchical RCU implementation.
    NR_IRQS:128
    Detected MIPS clock frequency: 404 MHz (202.497 MHz counter)
    Console: colour dummy device 80x25
    Calibrating delay loop... 403.45 BogoMIPS (lpj=201728)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    SMP: Booting CPU1...
    SMP: CPU1 is running
    Brought up 2 CPUs
    devtmpfs: initialized
    NET: Registered protocol family 16
    USB0: power enable is active high; overcurrent is active low
    PCI2.3->SDRAM window: 512 MB
    bio: create slab <bio-0> at 0
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    Linux video capture interface: v2.00
    Advanced Linux Sound Architecture Driver Initialized.
    PCI host bridge to bus 0000:00
    pci_bus 0000:00: root bus resource [mem 0xd0000000-0xefffffff]
    pci_bus 0000:00: root bus resource [io 0x0400-0x83ff]
    pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
    PCI host bridge to bus 0000:01
    pci_bus 0000:01: root bus resource [mem 0x10510000-0x1051ffff]
    pci_bus 0000:01: root bus resource [io 0x8400-0x87ff]
    pci_bus 0000:01: No busn resource found for root bus, will use [bus 01-ff]
    PCI: found device 14e4:8602 on SATA bus, slot 0 (irq 42)
    pci 0000:01:00.0: BAR 5: assigned [mem 0x10510000-0x10510fff]
    pci 0000:01:00.0: BAR 6: assigned [mem 0x10511000-0x105117ff pref]
    Bluetooth: Core ver 2.16
    NET: Registered protocol family 31
    Bluetooth: HCI device and connection manager initialized
    Bluetooth: HCI socket layer initialized
    Bluetooth: L2CAP socket layer initialized
    Bluetooth: SCO socket layer initialized
    cfg80211: Calling CRDA to update world regulatory domain
    Switching to clocksource upg
    FS-Cache: Loaded
    NET: Registered protocol family 2
    TCP established hash table entries: 2048 (order: 2, 16384 bytes)
    TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
    TCP: Hash tables configured (established 2048 bind 2048)
    TCP: reno registered
    UDP hash table entries: 256 (order: 1, 8192 bytes)
    UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    NFS: Registering the id_resolver key type
    Key type id_resolver registered
    Key type id_legacy registered
    Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    fuse init (API version 7.21)
    msgmni has been set to 255
    io scheduler noop registered
    io scheduler cfq registered (default)
    Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
    console [ttyS0] enabled, bootconsole disabled
    serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
    serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
    loop: module loaded
    PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
    scsi0 : sata_brcmstb
    scsi1 : sata_brcmstb
    ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
    ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
    Broadcom STB NAND controller (BrcmNand Controller)
    bcmemac: Broadcom STB 10/100 EMAC driver v3.0
    bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:01:55:58)
    bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
    usbcore: registered new interface driver zd1201
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    ehci-brcm ehci-brcm.0: Broadcom STB EHCI
    ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
    ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
    ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 2 ports detected
    ehci-brcm ehci-brcm.1: Broadcom STB EHCI
    ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
    ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
    ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 2 ports detected
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    ohci-brcm ohci-brcm.0: Broadcom STB OHCI
    ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
    ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
    hub 3-0:1.0: USB hub found
    hub 3-0:1.0: 2 ports detected
    ohci-brcm ohci-brcm.1: Broadcom STB OHCI
    ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
    ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
    hub 4-0:1.0: USB hub found
    hub 4-0:1.0: 2 ports detected
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    mousedev: PS/2 mouse device common for all mice
    i2c /dev entries driver
    IR NEC protocol handler initialized
    IR RC5(x) protocol handler initialized
    IR RC6 protocol handler initialized
    IR JVC protocol handler initialized
    IR Sony protocol handler initialized
    IR RC5 (streamzap) protocol handler initialized
    IR SANYO protocol handler initialized
    ata1: SATA link down (SStatus 4 SControl 300)
    IR MCE Keyboard/mouse protocol handler initialized
    usbcore: registered new interface driver btusb
    hidraw: raw HID events driver (C) Jiri Kosina
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    TCP: cubic registered
    NET: Registered protocol family 17
    Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    Bluetooth: HIDP socket layer initialized
    Key type dns_resolver registered
    EBI CS0: setting up NAND flash (primary)
    mtd->oobsize=0, mtd->eccOobSize=0
    NAND_CS_NAND_XOR=00000001
    B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
    brcmnand_read_id: CS0: dev_id=ecf10095
    After: NandSelect=40000101, nandConfig=55042200
    Block size=00020000, erase shift=17
    NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
    busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
    BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
    Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
    BrcmNAND version = 0x0201 128MB @00000000
    Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
    brcmnand_scan: B4 nand_select = 40000101
    brcmnand_scan: After nand_select = 40000101
    page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
    Brcm NAND controller version = 2.1 NAND flash size 128MB @18000000
    ECC layout=brcmnand_oob_bch4_4k
    brcmnand_scan: mtd->oobsize=64
    brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
    brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
    -->brcmnand_default_bbt
    brcmnand_default_bbt: bbt_td = bbt_main_descr
    Creating 7 MTD partitions on "brcmnand.0":
    0x000000000000-0x000007600000 : "rootfs"
    0x000007600000-0x000007a00000 : "kernel"
    0x000007a00000-0x000007c00000 : "boot"
    0x000007c00000-0x000007d00000 : "cfe"
    0x000007d00000-0x000007d80000 : "mac"
    0x000007d80000-0x000007e00000 : "env"
    0x000007e00000-0x000007f00000 : "nvm"
    PM: CP0 COUNT/COMPARE frequency depends on divisor
    UBI: attaching mtd0 to ubi0
    ata2: SATA link down (SStatus 4 SControl 300)
    UBI: scanning is finished
    UBI: attached mtd0 (name "rootfs", size 118 MiB) to ubi0
    UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
    UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
    UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
    UBI: good PEBs: 944, bad PEBs: 0, corrupted PEBs: 0
    UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
    UBI: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 937431069
    UBI: available PEBs: 0, total reserved PEBs: 944, PEBs reserved for bad PEB handling: 20
    ALSA device list:
    UBI: background thread "ubi_bgt0d" started, PID 48
    No soundcards found.
    UBIFS: parse sync
    UBIFS: background thread "ubifs_bgt0_0" started, PID 49
    UBIFS: recovery needed
    UBIFS: recovery completed
    UBIFS: mounted UBI device 0, volume 0, name "rootfs"(null)
    UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
    UBIFS: FS size: 115421184 bytes (110 MiB, 909 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
    UBIFS: reserved for root: 0 bytes (0 KiB)
    UBIFS: media format: w4/r0 (latest is w4/r0), UUID 6F059ABB-429A-4935-BAFF-001DCF3606FA, small LPT model
    VFS: Mounted root (ubifs filesystem) on device 0:10.
    devtmpfs: mounted
    Freeing unused kernel memory: 300k freed
    INIT: version 2.88 booting
    procmk_init
    dvb_bcm7335: module license 'Proprietary' taints kernel.
    Disabling lock debugging due to kernel taint
    DVB: registering new adapter (bm750)
    bcm7335: hotplug_callback():
    Hotplug - status.connected 0
    CPU 0 Unable to handle kernel paging request at virtual address e071d620, epc == e071d620, ra == 80078048
    Oops[#1]:
    Cpu 0
    $ 0 : 00000000 30008300 e071d620 00060000
    $ 4 : 0000000d e0b88e64 00040000 004b213c
    $ 8 : 30008700 1000001f 773b0000 ffffffff
    $12 : 0000002f 773d6000 00000000 004808c4
    $16 : 00000000 00000000 0000000d 80726f00
    $20 : 80730000 00000000 8069ec7c 004ae8f0
    $24 : 00000000 7725edb8
    $28 : 87d82000 87d83d78 87a7cf80 80078048
    Hi : 0000007b
    Lo : 00035a87
    epc : e071d620 0xe071d620
    Tainted: P O
    ra : 80078048 handle_irq_event_percpu+0x5c/0x274
    Status: 30008302 KERNEL EXL
    Cause : 00800008
    BadVA : e071d620
    PrId : 0002a044 (Brcm4380)
    Modules linked in: procmk(O)
    Process mdev (pid: 98, threadinfo=87d82000, task=87d0b6f0, tls=773dc920)
    Stack : 00000163 87c29540 30008701 30008701 00000028 00000075 80726f00 00001400
    00000000 00000001 00000020 00000000 00000001 004ae8f0 004b0000 800782b0
    87d81770 00000000 7725d8fc 87c2953c fffffff7 800ad4a8 80726f00 8007bc0c
    00000000 00000000 00001400 00000000 0000000d 8007769c 30008703 0000012e
    0002aefe 800d8738 0000000d 80007944 87c87230 00000028 7725d8fc 87c29500
    Call Trace:
    [<800782b0>] handle_irq_event+0x50/0x90
    [<800ad4a8>] handle_pte_fault+0x3c0/0xe6c
    [<8007bc0c>] handle_level_irq+0xd4/0x15c
    [<8007769c>] generic_handle_irq+0x3c/0x54
    [<800d8738>] path_openat.isra.52+0x148/0x4ac
    [<80007944>] do_IRQ+0x18/0x24
    [<80002894>] brcm_intc_dispatch.isra.0+0x90/0x20c
    [<800ae094>] handle_mm_fault+0x140/0x1b4
    [<80307f28>] __up_read+0x20/0x6c
    [<80002ad8>] plat_irq_dispatch+0xc8/0x104
    [<80010ec8>] do_page_fault+0x348/0x3f0
    [<80005b68>] ret_from_irq+0x0/0x4
    [<80012b88>] tlb_do_page_fault_0+0xf8/0x11c
    Code: (Bad address in epc)
    ---[ end trace 4bdbd900f58e0ac6 ]---
    Kernel panic - not syncing: Fatal exception in interrupt
    Rebooting in 180 seconds..
  14. #14
    Aug 2015
    This log is with the image that is ON but the tuner is locked
    BCM73350010
    012
    Shmoo Version=1.9
    MEMC-00000000 RW=00000010 WW=00000046 G=00000001 R=00000009 W=00000017
    MEMC-00000001 RW=00000010 WW=0000004D G=00000001 R=0000000A W=00000006 #$
    3
    COPY CODE
    A567
    writing vfd
    DDR Freq: 395MHz
    CPU speed: 405MHz
    Device Tech: 1Gb
    Total memory: 384MB
    Boot Device: NAND
    ECC: Hamming
    Total flash: 128MB
    Initializing USB.
    CFE initialized.
    checking usb
    0x80001000/6969600 0x806a6900/137904 Entry address is 0x8052b040
    TP1 Entry Address at 0x80000ffc = 8052b040
    Starting program at 0x8052b040
    Linux version 3.9.6 (buildserver@buildserver) (gcc version 4.6.4 20120303 (prerelease) (GCC) ) #1 SMP Mon Nov 24 13:22:51 CET 2014
    Zone ranges:
    Memory: 132036k/262144k available (5329k kernel code, 130108k reserved, 1237k data, 276k init, 0k highmem)
    NR_IRQS:128
    Brought up 2 CPUs
    FS-Cache: Loaded
    Registering unionfs 2.5.13 (for 3.9.11)
    msgmni has been set to 257
    loop: module loaded
    Success! Registering the characther device success with 0
    blackhole initialised
    UBI: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1147375604
    ALSA device list:
    UBIFS: parse sync
    UBIFS: media format: w4/r0 (latest is w4/r0), UUID 06AD52AF-990F-43CB-BDFF-8F15C591C78D, small LPT model
    devtmpfs: mounted
    Freeing unused kernel memory: 276k freed
    zram: module is from the staging directory, the quality is unknown, you have been warned.
    zram: Created 2 device(s) ...
    mke2fs 1.42.1 (17-Feb-2012)
    Adding 33076k swap on /dev/zram1. Priority:-1 extents:1 across:33076k SS
    NET: Registered protocol family 10
    procmk_init
    brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
    [VID]: 6bcm7335_video_init
    [AUD]: 6bcm7335_audio_init
    BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
    [MPVR]: >> misc_pvr_init
    input: dreambox advanced remote control (native) as /devices/virtual/input/input0
    [LCD]: registered
    [CI]:-BM750_PCB_1_2
    [CI]: registered ci0
    [CI]: registered ci1
    [DFP]: registered dbox fp
    [DFP]: Scart 6417 is found 3
    [SC]: registered sci0
    [SC]: registered sci1
    system_time_set wakeup mode get
    system_time_set wakeup mode get 0xc4
    EXT4-fs (zram0): mounting with "discard" option, but the device does not support discard
    EXT4-fs (zram0): mounted filesystem with ordered data mode. Opts: discard
    Startting the hotplug events dispatcher
    udevd (124): /proc/124/oom_adj is deprecated, please use /proc/124/oom_score_adj instead.
    Synthesizing the initial hotplug events
    Waiting for /dev to be fully populated
    udevd-event[250]: node_symlink: rename(/dev/fb.udev-tmp, /dev/fb) failed: Is a directory
    done
    Displaying bootlogo.
    [VID]: VIDEO_SET_STREAMTYPE 0
    [VID]: VIDEO_SELECT_SOURCE 1
    [VID]: VIDEO_PLAY 1 2 0
    [VID]: VIDEO_CONTINUE 1 1
    [VID]: VIDEO_CLEAR_BUFFER 1 1 0
    [VID]: VIDEO_STOP 0 1
    [VID]: VIDEO_SELECT_SOURCE 0
    Configuring network interfaces... bcmemac: eth0 NIC Link is Down
    udhcpc (v1.19.4) started
    Sending discover...
    Sending discover...
    Sending discover...
    No lease, forking to background
    done.
    zeroconf calls setitimer() with new_value NULL pointer. Misfeature support will be removed
    Starting portmap daemon...
    net.ipv4.conf.default.rp_filter = 1
    net.ipv4.conf.all.rp_filter = 1
    INIT: Entering runlevel: 3busybox 1.19.4) starte
    Starting system message bus: dbus.
    Starting Dropbear SSH server: dropbear.
    Starting automounter: loading autofs4 kernel module, done.
    [SCRIPT] start: Common Interface
    Starting HOSTAP Daemon: Configuration file: /etc/hostapd.conf
    Could not open configuration file '/etc/hostapd.conf' for reading.
    Starting internet superserver: inetd.
    creating NFS state directory: done
    starting 8 nfsd kernel threads: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    svc: failed to register lockdv1 RPC service (errno 124).
    done
    starting mountd: done
    starting statd: done
    exportfs: No host name given with /media/hdd (rw,async,wdelay,hide,nocrossmnt,secure,no_root_sq uash,no_all_squash,no_subtree_check,secure_locks,a cl,anonuid=65534,anongid=65534), suggest *(rw,async,wdelay,hide,nocrossmnt,secure,no_root_s quash,no_all_squash,no_subtree_check,secure_locks, acl,anonuid=65534,anongid=65534) to avoid warning
    Starting syslogd/klogd: done
    UsbTuner v0.3.15-BETA2 (Build using DVBAPI 5.10)
    * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
    ...done.
    Starting virtual private network daemon: Autostart disabled.
    /etc/rc3.d/S99udpxy: line 2: ./udpxy: not found
    setenv('prefix', '/usr', 0)
    setenv('exec_prefix', '/usr', 0)
    setenv('bindir', '/usr/bin', 0)
    setenv('sbindir', '/usr/sbin', 0)
    setenv('libexecdir', '/usr/libexec', 0)
    setenv('datarootdir', '${prefix}/share', 0)
    setenv('datadir', '/usr/share', 0)
    setenv('sysconfdir', '/etc', 0)
    setenv('sharedstatedir', '/com', 0)
    setenv('localstatedir', '/var', 0)
    setenv('libdir', '/usr/lib', 0)
    setenv('localedir', '${datarootdir}/locale', 0)
    setenv('prefix', '/usr', 1)
    setenv('exec_prefix', '/usr', 1)
    setenv('bindir', '/usr/bin', 1)
    setenv('sbindir', '/usr/sbin', 1)
    setenv('libexecdir', '/usr/libexec', 1)
    setenv('datarootdir', '/usr/share', 1)
    setenv('datadir', '/usr/share', 1)
    setenv('sysconfdir', '/etc', 1)
    setenv('sharedstatedir', '/com', 1)
    setenv('localstatedir', '/var', 1)
    setenv('libdir', '/usr/lib', 1)
    setenv('localedir', '/usr/share/locale', 1)
    resolve: resolve ${datadir}/enigma2/encoding.conf
    resolve: -> /usr/share/enigma2/encoding.conf
    resolve: resolve ${libdir}/enigma2/python
    resolve: -> /usr/lib/enigma2/python
    PYTHONPATH: /usr/lib/enigma2/python
    enigma2 is the main pvr application... adjust oom score!
    + (1) Background File Eraser
    + (5) Tuxtxt
    + (8) graphics acceleration manager
    + (9) GFBDC
    12150k video mem
    - double buffering available!
    4050kB available for acceleration surfaces.
    resolution: 1280 x 720 x 32 (stride: 5760)
    + (9) gLCDDC
    found OLED display!
    lcd buffer 0x6d57c0 8448 bytes, stride 132
    + (9) Font Render Class
    [FONT] initializing lib...
    [FONT] loading fonts...
    [FONT] Intializing font cache, using max. 4MB...
    + (10) gRC
    RC thread created successfully
    + (15) eWindowStyleManager
    + (20) DVB-CI UI
    + (20) Hdmi CEC driver
    + (20) UHF Modulator
    couldnt open /dev/rfmod0!!!!
    + (20) RC Input layer
    + (20) misc options
    + (20) AVSwitch Driver
    + (21) input device driver
    Input device[CI]:ci_dev_open
    "dreambox advan[CI]:Opening A GPIO's for 7335 platform
    ced remote contr[CI]:Opening A GPIO's for 7335 platform....done
    ol (native)" is [CI]:entering.. A NEXUS_DvbCi_Open
    [CI]:NEXUS_DvbCi_Open done..
    Found 1 input d[CI]:Installing callbacks
  15. #15
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    What satellite are you pointed at and are you using an up to date channel list?
