Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: e65 9999999
  1. #16
    dashradio's Avatar
    Inafield
    Quote Originally Posted by Dashfixer63 View Post
    talk to me please
    What is the car model
    Send me files
    What part of post #1 did you not understand ?
    Make & Model
    Both Files
  2. #17
    Mar 2016
    I waiting for new cas
    I have
    diagnostic bmw explorer full /avdi commander full
    programer motorola mcu smok jtag /upa s usb
    programer m35080 martech box3 and smok eraser
    a lot of equipment Zero talent
    in attachments log from bmw explorer
  3. #18
    If car starts try writing mileage in cas with smok
  4. #19
    Mar 2016
    I try ... not work
  5. #20
    Oct 2016
    talk to me please
    whatsapp:0096550105538
  6. #21
    korrni's Avatar
    UE
    talk to me please
    Hello, did you get it sorted out? I have the exact same problem.
    Thanks, guys!
  7. #22
    Mar 2017
    Bulgaria
    Hi I have some problem when the mileage in dash not correctly writen, and eep not erased full, check again 0000 and 0010 in 35080V6.
    Read again dash eep and check it. korrni
  8. #23
    Nov 2011
    Macedonia
    Quote Originally Posted by slawo1z View Post
    BMW E65
    dash show 999999
    car arrived with such failure
    help
    if anyone use option reset service interval with delphi diag....dash is corrupted.........for this situation use NCS Expert and last sp datten use default option kombi and all will be ok ....dont touch cas.......i have same problem with e65
    symptoms:
    dash 999999 and dot
    on-board does not work
    Baze007
  9. The Following User Says Thank You to baze007 For This Useful Post:
    uadi (30th June, 2019)
  10. #24
    korrni's Avatar
    UE
    Quote Originally Posted by SKODANIKOV View Post
    Hello and thank you for your quick reply.
    Actually, my 35080V6 seems that is corrupted, I looked down where the VIN is written and seems that is not the same with the VIN written in CAS. I will post both the Kombi Dump and CAS Dump.
    Thanks.
  11. #25
    korrni's Avatar
    UE
    After coding with NCS Expert and reflashing (although the Flash part was ok) with Winkfp, the red dot tampering dissapeared and the mileage was correct in the instrument cluster, but the error "Speedometer Display Faulty" still remains on the dash and the error code 931E eeprom checksum error was still present. If anybody has a 35080 dump for the Part Number 6211 6956632, I would thank you!
  12. #26
    Jan 2019
    France
    Quote Originally Posted by baze007 View Post
    symptoms:
    dash 999999 and dot
    hello all
    i have the same problem here
    bmw 730i e65 2003
    tried to deactivate the cbs with delphi and after that the dash show 999999 km with a dot in the upper side. for a second i can see the real mileage but after that it change to this
    i will buy a ncs expert cable , can you guide me with this?
    thanks in advance
