Results 1 to 15 of 26
Thread: e65 9999999
    Mar 2016
    Default e65 9999999
    BMW E65
    dash show 999999
    car arrived with such failure
    help
    maybe eprom in dash damage!
    change it.
    Apr 2016
    Quote Originally Posted by slawo1z View Post
    BMW E65
    dash show 999999
    help
    E65.rarE65.raroriginal: 299112KM
    try and report
    Mar 2016
    I try ........
    the same problem
    kachimbi's Avatar
    Oct 2012
    maybe eeprom is faulty or where the eeprom is soldered there is solder thats causing short circuit..
    Jan 2016
    South Africa
    is eeprom 35080v6?
    Oct 2016
    BMW E65
    dash show 999999
    help
    check the soldering 100% is soldering problem if you used digimaster 3 by wiring from the back it ask you to remove one of the capacitors legs
    need to put back in
    or something's shorted in he das
    cas has noting to do with 999999
    hope that help
    Mar 2016
    35080v6 yes
    Mar 2016
    Quote Originally Posted by parmoda View Post
    need to put back in
    hope that help
    this dash
    never open
    Before he started showing 9999999
    I opened it first
    When 999999 already
    situation
    dash show 9999999
    when I disconect cas
    dash show normal km 299xxx km
    I think dash its OK
    need to put back in
    hope that help
    for sure cas can also make mileage go 999999
    Mar 2016
    1 only dash connect
    2 dash +cas
    3 dash +cas + key
    i think your cas is currupt or damage.
  13. #13
    Oct 2016
    talk to me please
    What is the car model
    Send me files
  14. #14
    Oct 2016
    What device do you use?
  15. #15
    Oct 2016
    The problem is in cas
    Do you want to repair
    tell me please
